d-17 erratic firing ??
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: d-17 erratic firing ??
    Posted: 09 Jun 2019 at 4:19pm
That d-17 I rebuilt last winter has got one last bug to get out. I've got about 15hrs on the rebuild: mostly from a parade/ tractor show & a little hay making. I actually got compliments on how smooth it ran, these folks only heard it at idle.  The problem is at 3/4 to wide open throttle it will pop, not backfire just an irregular pop from the exhaust.Here's what I have done to try to fix the problem        1]  got a rebuilt carb from Dans tractor supplies, he's supposed to be one of the best-   was supposed to be preset on a running engine, did'nt help tried some adjusting myself, no luck        2] changed plugs, napa points- condenser, took cap & wires off my wd45 no luck               3] valve lash has been checked 4 times per manual                                                         4] plenty of gas flow- the tank was cleaned & sealed during rebuild                                    I bought a timing light,I was close by ear, but it looks like it is not firing at the same place I'm warmed up & pretty much wide open during this check. Should the mark be rock steady when it fires??  Yes the dist. has slack in it but so do my other 6 AC's they all run like a swiss watch. The dist shaft has no wobble just a lot of back-lash. Sorry for the long post- shes driving me crazy& to the poor-house!!!!!
Bradleytrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bradleytrench Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2019 at 6:21pm
I would check the distributor advance weights and springs. Id also check to see how much play is in the distributor shaft and bushings. Bobby Mo
1 WD45D, 1 A2 GLEANER, Wd w 33mounted corn picker
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2019 at 7:17pm
I checked the advance wts & springs, they were clean & free so I gave them a little shot of wd-40. There is no wobble or side to side play, but there is back-lash, just don't understand why the other 6 run fine with the back-lash.
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2019 at 9:21pm
When you rebuilt the motor did you use new valve springs or check the spring tension? Where the guides replaced?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2019 at 9:23pm
Is it a early D17 with power steering? If so drive gear on governor shaft Is worn out.          MACK
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 9:56am
A bad condenser, weak point spring, or weak valve would all be appropriate suspects, as would be a tiny crack or leak in an exhaust manifold, but what you've noted is the best clue here... you're not getting a steady ignition event.  Weak point spring, bad condenser, and dirty points would be my first, simply becausue they're quick and easy.
The Delco-Remy distributor in the Allis engine develops slop, and as you noted, usually in the radial plane, and this slop means that the point cam's lift point is directly affected.  Radial slop means the cam lifts the points inconsistently, AND, the ignition dwell time is wrong, which at high speed, can cause a really blatant miss.
Vertical motion may not SEEM like it can cause timing issues, but the timing gears below will cause the shaft to kick around, again causing an unstable event... See the gears on the bottom of the distributor?  if it's walking vertically, your timing will change.
As Mack noted, the governor gear may also be worn... look at how the distributor drive works-  from the governor housing, a horizontal shaft driven by governor gear, to a 90 degree worm (rather than bevel) drive.  When ANY of these gears exhibit slop, the result is opportunity to affect timing event stability.
IF the governor gear is good, drive out the crosspin, remove the distributor drive gear, and install a thin washer or three between gear and housing, to take up the vertical slop, then reinstall gear and crosspin, reinstall, set timing, and try again.
Another thing to note... how BAD is this occasional 'pop'?
Many do not realize that running at high idle (meaning, full governed speed) with no load, includes a little popping.  Why?  Because the engine is spinning fast, the cylinders want to fill completely, but the governor is restricting the flow of fuel.  Why?  Because there's NO LOAD... the throttle, being closed, is limiting fuel, thus, it's pretty darned lean in that chamber.
It wasn't designed to be a  smooth running engine at full speed, while doing no work... it was designed to be smooth and efficient under a HEAVY load...  so, Put a load on it... make it work.  Does it still pop?  If so, then explore the situation.  If not, call it normal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2019 at 5:50pm
Thanks to all, I guess i'll try another set of napa points/condenser. If that doesen't do it, I'll try the vertical motion fix, thanks Dave.  It doesn't have power steering.  I just wish it would run half as smooth as my worn -out oil burning/leaking, little to no oil pressure, WD-45!!!  The pop is not a back-fire & is intermittant, also does the same thing under load [hay conditioner] . keith so.va.
