Wheelhorse riding mower |
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Topic: Wheelhorse riding mowerPosted: 08 Jun 2019 at 2:49pm |
I picked up this Toro Wheelhorse riding lawnmower (model 71223, w/Briggs and Stratton model 28?(maybe 6)777 Type 0690-E1, code 000202ZE) to tinker with w/grandson. Couple of questions, on the bottom of the carb bowl is a gizmo with two wires, one of which is ground, don't know yet where the other goes, yet. Any ideas what it does? I don't see it identified on the wiring chart in the owners manual.
The thing starts and runs, but driving it around it will occasionally backfire and then continue on? doesn't seem to be any reverse. and, in the forward positions it does go, but there is a significant delay between releasing the clutch/brake pedal and actually moving forward. I have no idea how/what the transmission is/works, except I doubt it is a hydrostatic. Looks like a straight forward gearbox (5 forward 1 rev), driven by a belt from motor, to me. But I don't understand the delay in moving. way more time delay than can be explained by worn gears. maybe drive belt slipping, but it doesn't make noise or smell. and once its moving it seems to haul my lard bottom around no problem, even up hills. Any thoughts I showed it to grandson and told him he will be working for me this summer and that this tractor will be assigned to him. He will be responsible for it's care and maintenance....I will show to do the maintenance, check oil, clean air filter, grease it, clean it, etc. I bought him a cart for it. I bought it with a crappy mower deck, which I removed. I have four acre lot that I had the building dozed over and buried. But that left a lot of rocks and debris, plastic, wood, car parts, etc scattered all over. His job this summer will be driving around picking up all this loose crap so I can seed grass. His mom says he is so excited he is vibrating! Edited by LouSWPA - 08 Jun 2019 at 2:55pm |
I am still confident of this;
I will see the goodness of the Lord in the land of the living. Wait for the Lord; be strong and take heart and wait for the Lord. Ps 27 |
Dave in PA
Joined: 13 Sep 2009 Location: Mars/Wexford PA Points: 2631 |
Posted: 08 Jun 2019 at 3:18pm |
Lou, As for the 2 wires on the carb, one will be a ground, the other a + hot 12 volt to open the shut off to the needle valve in the carb. It should work when the key is in the start/run positions. When turned on, You should hear a slight CLICK, as it opens. Then when shut off, the same type click, to shut off. IF not, it my be bad, and not good. It could fill and flood the crankcase with gas if the valves are in the wrong, open position! Then ya crank it over, and pop the case. As for the belt, tranny issue, I would think that maybe the OLD belts is taken its run time, and a bit longer than it should be?? BUT either way, what a great time you will BOTH have with this!!! Hope this helps, let me know! Dave p.s. Us older guys might not be able to hear the click, I installed a gas shut-off, and just let it run out, and stall, does the same thing! |
LouSWPA
Posted: 08 Jun 2019 at 7:22pm |
Thanks Dave, that does help. and, as for the click, not hearing it, I doubt I would. That has been a problem at work for me. we have some equipment that uses different buzzers, sonalerts, etc for alarms, alerts etc. well, guess what, I cannot hear them at all. I'll be working away on a piece of equipment, and a customer will come over, rather distraught and ask if I can turn the alarm off. Seems they been listening to it for the last 20-30 mins and I am totally oblivious to it!
anyways, thanks for the input. I put the boy to work today, wife says he a totally different boy now! I gave him a machine, a task, some instruction, and turned him loose to accomplish it on his own. exactly what most farm boys grew up with |
truckerfarmer
Joined: 26 Jan 2013 Location: Watertown, SD Points: 3312 |
Posted: 08 Jun 2019 at 9:22pm |
May want to check out MyTractorForum.com. Haven't been on there in a while, but as I recall, I believe there is a couple Wheel Horse gurus over there.
'53 WD, '53 WD45, WD snap coupler field cultivator, #53 plow,'53 HD5B dozer Duct tape.... Can't fix stupidity. But will muffle the sound of it! |
LouSWPA
Posted: 08 Jun 2019 at 9:30pm |
thanks Trucker
shameless dude
Posted: 08 Jun 2019 at 9:35pm |
neighbor had a wheelhorse and it would backfire a lot, it was also new at the time.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25255 |
Posted: 09 Jun 2019 at 5:57am |
Dave's 100% right about the 'anti-dieselling' solenoid valve. Fun fact... leave the key in the 'on' position and it'll drain the battery overnight....... I'm thinking ,kinda hard, about adding a bright LED to remind, um 'someone' to remove the key.... Slow response in the drive train sounds like worn, oil soaked belts and slippery pulleys. A few drips of engine oil always find drive belts ..... BTW, the engine was built in Feb of 2000 ( 'code' 000202' mean 2000-feb-02 ). Providing it's the original engine, thactor was built then or few months later. Jay
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8661 |
Posted: 09 Jun 2019 at 6:19am |
Lou,
There is or was a Wheel Horse forum too. I havent been on it for years. I believe "Red Square" is the name of the forum. Just as much info as you wanted on there! Sounds like you have a good helper! Regards, Chris
Edited by Sugarmaker - 09 Jun 2019 at 6:21am |
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 09 Jun 2019 at 8:01am |
https://www.wheelhorseforum.com/ Yep its there.
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 11 Jun 2019 at 12:27am |
Looks like a good place to learn about Wheelhorse machines! |
Allis Express participant |
ford8nwd
Posted: 11 Jun 2019 at 6:17am |
Lou, Lawn world forum has a good section also. Might want to check out hearing aids, too. Could be time.
LouSWPA
Posted: 11 Jun 2019 at 7:21am |
I have hearing aids, still cant hear certain frequencies, such as the alerts on many of our products |
