AC D17 Power Director Popping Out of High
Gary Va View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Va Quote  Post ReplyReply Direct Link To This Post Topic: AC D17 Power Director Popping Out of High
    Posted: 06 Jun 2019 at 5:44pm
I have a great running and very reliable 1963 AC D17 Series III gas tractor and recently it will occasionally pop out of the high range on the power director lever. The low range stays in fine and it will sometime holds in the high range but will sometimes pop-out and when I re-engage it pops right back out. It does not seem to matter whether it is under load or not, has happened both ways but not all of the time. Does this sound like a shim adjustment going into the power director side panel or more of a roller or power directo clutch  replacement issue that means breaking the D17 apart?
Any insight or suggestions on my high range power director problem would be appreciated. Also, the fluid I utilize in the power director is Hy-trans, hope that is not a problem.
Thank, Gary
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2019 at 6:19pm
The rollers have worn a grove in the pre-load plate. Will need to remove to fix.
Click on link below
Power Director
Edited by DennisA (IL) - 06 Jun 2019 at 6:19pm
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Va Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2019 at 6:50pm
Dennis,
Thanks for the Power Director Rebuild video on Youtube, I will definitely have to find a good AC mechanic to perform this power adjuster rebuild as those pre-load plates on the high side must be worn to allow the rollers to fall into neutral. Thanks Dennis
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2019 at 9:18pm
Before tearing the tractor apart, take a few washers out of bolt that the hand clutch rests on when you have it in high range.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2019 at 7:55am
I have gone through the shim adjust with no luck. Ended up with the roller plate replacement. While I had it apart I put in a new foot clutch pedal shaft and O-ring for the PTO lever.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2019 at 9:24am
My D19 started jumping out of high range I took the the bolt and all the washers out
that worked for another 15 years.Then it started jumping out again I cut a notch on the
guide so it was locked in high range been that way for about 10 years doesn't slip in high range just have to push the button down to take it out of high.Tractor isn't worth tearing down and replacing everything but as long as it works I'll keep using it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Va Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2019 at 11:39am
Gary,
Thanks and what a great suggestion that I will try before tearing the D17 apart. With the new notch that you put in the plate to lock in the lever, does it always stay in high range?
It definitely is worth trying as my low side stays in just fine. Thanks for the insight Gary!
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2019 at 12:06pm
Just to let you know that more damage could be done by forcing the clutch to stay engaged.
My uncle did this to the D-17. It lasted 4yrs. and the hand lever wouldn’t work for high or low. What happened is the clutch was trying to push out of high in to neutral, but since the lever was locked in place it wore out the brass shifting collar. All that this did was prolong the correct fix for the issue and add about $500 to the repair. That collar is over $400.00.
Thanks & God Bless
Dennis
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2019 at 1:31pm
If taking a washer or two out gets the snap back your good if Allis engineers put the adjustment there it’s there for a reason holding it in place will cause more wear but only if it doesn’t snap    Me I would adjust the shims first more than likely that needs to be done anyway from time then adjust the stop and see what you got
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Va Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2019 at 2:17pm
Dennis,
Thanks and this is why the AC Forum works so well, we get the benefit of a lot of different experiences, perspectives and practical insight into a problem. Thanks for your time and insight and what you describe that could happen by forcing the lever in place does makes sense!
Thanks,
Gary
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2019 at 4:34pm
Interesting post . It's a stretch to push my D 15 power director in high . Wondered how someone shorter than my 6' self managed . Then I noticed that the stop bolt was gone . Now I know why . Thanks !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2019 at 5:33pm
Originally posted by Gary Va Gary Va wrote:
Dennis,
Thanks,
Gary
No problem, I didn't mean to suggest that you rebuild the clutch. I just wanted you to know why it's jumping out of high range. In the video I point out the cause. Most guys understand better by seeing than by reading.
I have found that I look at things a little differently than others. If any of my tractors have any issues I fix them. I don't look at how difficult it is, how long it will take or how much it will cost. If it's broke it gets fix. In your situation I would split the tractor in replace the pre-load plate, that's just me.
Prices keep going up and parts keep getting harder to find. So I fix now why parts are still available. A case in point is the fuel gauge for the D-17. My uncle wanted me to replace the gauge. He found out that it cost $65.00. Well that's was just way to much for him. He said forget get it. About 4 years went by and he told me to get the gauge. He got tired of running out of gas in the field. Well now the same gauge cost $145.00. So the price over doubled and he lost 4 years of use.
I always tell him if you can't afford to fix and maintain your equipment then you should just get rid of it because you can't afford to own it.
I wish you well!
Thanks & God Bless
Dennis
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2019 at 5:55pm
reminds me of when we molboard plowed with a S/2 D 17. Start the furrow in 2 LO,let the RPM's feather out and SNAP it fast into Hi. When cold, it would pop out of Hi so when snapped into high, we would hold our right foot on the "stick" for a round or 2 until the tranny got warmed up. After a round or 2, didn't need to hold the "stick". Hindsight it should have had some attention, but it worked for 5 years Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2019 at 6:27pm
Dennis,
Thanks,
Gary
I wish you well!
For me it never makes sense to put more in a repair on any machine that will cost 2X  what I can buy a replacement machine in working condition.I stick with the same models of tractors and equipment when one gets to the point of needing costly repairs
I start using its backup and use the tractor that needs repairs for parts.Pretty soon I have about all the parts I'll need plus also sell some to recoup original investment too.
Having my own parts supply saves me a lot of money over time plus its nice to have them on hand.I ain't married to any of these machines(LOL)
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2019 at 8:36pm
If the ramps/rollers are worn, going thru the shimming procedure will usually make the cold oil jump-out problem worse. Suit yourself.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2019 at 9:34pm
The stop bolt on the high side is there to prevent a 300 pound super farmer from leaning forward and with all that weight popping an ear off the shifter. It is not needed for low range. The bolt is shim adjusted to allow for wear and hit the stop at the perfect position. An old hand once showed us a trick at service school - he replaced the rollers for the wear in the bearing surface on each side of the roller in the middle. He had a high speed drimmel and would put about a one or two degree angle on the pressure plate and work it back into the groove the roller makes. When the roller goes over the edge it now rolls down and will not pop out. He also deepened the grooves one finds are there just a tad to allow the levers to go just a few thousands more. I did this to our D17 at about 5000 hours and it now has about 10000. If you are not willing to have to do it again if this does not get done properly = pop for the new parts. Also the neutral adjustment is equally important - the clutch should be put in the absolute center - neutral position. When using the tractor for long times on the pto as in a grain auger- always leave it snapped in range = trans in neutral .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Va Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2019 at 7:43am
Thanks for all of the input and unfortunately for my wallet it is time to break it apart and have the power director serviced for all worn parts. Found an AC mechanic in Hartfield VA that is going to help on this project.
Like this old '63 D17 way too much to not get it corrected! Thanks again, Gary
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2019 at 10:24am
It's one of those things that is a bit painful-in-the-hind-pocket to do, but once it's done, it lasts a LONG time.  She was built in '63, that's 56 years... it may very well be that it's never been serviced.  Let's say it costs you $500 in parts... that's $8.92/year...
While I understand Gary's point (buying a replacement machine), the fallacy, is that the replacement machine will have any more substantial service life, or not have other issues that would be eliminated by a simple investment of effort into the current machine.
Many people fall into that trap.  Tearing down and giving a proper rebuild to a good machine is ALWAYS a good investment, when the machine serves your purpose well.  When I have to pull apart some machine, I don't undertake a great dismantling without attending to everything else that's accessible in that operation... because it's not the cost of the parts which constitutes the greatest investment- it's the time and effort to GET IN THERE, and the lack of availability amidst down-time.  If you're splitting a tractor to rehab the power director, give it a clutch, transmission bearings, etc., so that when you button it back up, you KNOW that the other parts will NOT be demanding that you will split it again in the future.  A man always sleeps better knowing that he won't have to repeat the same job twice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2019 at 1:59pm
Had a 170 do this for years ,, a simple put your foot on it holds it in ,, just like a gear jumping One Hundred series factory flaw about jumping out of gear,, a lot of labor hours to get to the real problem
Walter(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walter(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2019 at 5:29pm
A few years ago my 175 would jump out of Hi range.  The problem with my was the tapered set bolt that holds the lever to the shaft was not tight in the tapered hole and the clutch was not fully engaging.  Turned the jam nut loose and tighten set bolt and than tighten jam nut , cured the problem. Probably a rare instance but is worth checking since I had this problem on my 175.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Va Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2019 at 5:46pm
Walter, thanks and I will check out the connection of the lever to the shaft as you suggested. Thanks, Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2019 at 5:31am
While  everyone is certainly free to spend their money anyway they want I can say for sure its not ALWAYS a good thing to go in and spend a bunch of money on a tractor.
I've bought a good many tractor 'projects' over the years.Some were unfinished because of lack of interest,some because the owners got tired of throwing money at it.
Not everyone has the extra cash lying around when a 1K$ job turns into a 5K$ job usually they spend a lot then have to sell for pennies on the Dollar$.Even if finished
many times people regret spending a huge sum of money on a common tractor that can be bought easily for half or a quarter of what they spent.Sink 5K$ in a transmission/rear
rebuild, put a few hours on it and then the engine blows on the 50 year old tractor.
Its then more $$$$$ or cut the loses and sell.
