allis planters |
Post Reply ![]() |
7010 ![]() Bronze Level ![]() Joined: 20 Dec 2010 Points: 117 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Jun 2019 at 10:53pm |
Any Allis planters still in use out there? Any for sale?
Richmar ![]() Silver Level ![]() ![]() Joined: 03 Aug 2010 Location: Ia Points: 205 |
7010
I have a 600 series 4 row no til and have advertised it on hear a few times Rich |
allisbred ![]() Orange Level Access ![]() Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
My father is still using a 500 series planter and manages high yields per our county standards, sometimes over 225. Just had new sprockets made this spring for a goal of 250 plus, county average is around 130. These old planters can hang in there, so don’t let someone tell you differently.
TedBuiskerN.IL. ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
used an Allis 500 plate planter for years until I quit and rented the land out. Most accurate planter for population ever, if you can get well graded corn. Plants circles around a JD 7000 for population control.
There’s an irony in your thoughts—lol. He gets a lot of attention from the nutrient management & insurance adjusters on his yields validating the BPA along with local farmers no matter of the weather conditions. When they see the ac planter, they think he’s messing with their minds!
cabinhollow ![]() Orange Level ![]() Joined: 24 Mar 2018 Location: SEKY Points: 327 |
Here's the one I use.
shameless dude ![]() Orange Level ![]() ![]() Joined: 10 Apr 2017 Location: east NE Points: 13607 |
I also have/use a 600 double disk opener planter. 6-30. and like Ted said above, mine is also very accurate on seed placement and population. better than the Kinze and jd planters I've owned
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
I had a 330 Allis with 78 air units and I think it planted more accurate than my White 5100 does. The White is good but the Allis was simpler in my mind accept it was harder to change depth but then I planted beans and corn at the same depth so I never changed it.
Wink I am a Russian Bot |
Kurt WI ![]() Orange Level Access ![]() Joined: 19 Oct 2011 Location: Cascade WI Points: 3242 |
I have a MF 640 that allis built otherwise the same as a 330.
WD D17D 170 190xt 190xtIII 200 7020
dertz19 ![]() Bronze Level ![]() Joined: 22 Sep 2009 Location: Minnesota Points: 95 |
If I could find another 330 but in 6 narrow close by me and in good shape I'd consider buying one back. It has a certain simplicity that I like better than my White 5100.
bleeds orange ![]() Orange Level ![]() ![]() Joined: 11 Sep 2012 Location: mt. vision, ny Points: 692 |
SGTJ ![]() Bronze Level ![]() ![]() Joined: 15 Apr 2019 Location: La Valle, WI Points: 106 |
I've been using the little two row planter that I picked up with a CA a few months back -- still works like a champ and does a fine job planting sweet corn !
WD , CA
I've also got an 8 row 3-pt planter, and a lot of different attachments that will fit most of any of them. I did change the planter boxes to the taller fiberglass boxes instead of the plastic ones. and I have a set (2) of the new fertilizer boxes. never been mounted.
GM Guy ![]() Orange Level ![]() Joined: 31 Jul 2012 Location: NW KS / S.C. ID Points: 1985 |
I dont think I can find the article quickly, but I recall within the last 5 years a little "insert" within one of the major ag magazines (Successful farming, etc) that was sponsored by John Deere and Pioneer showing top 10 yields in each state, and of course if they planted Pioneer and harvested with a Deere, it was highlighted in green.
The guy in Kentucky I believe had the highest yield in the state and has a 333 Allis planter. No green highlighting in his column... lol |
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help. |
Johnwilson_osf ![]() Orange Level ![]() Joined: 29 Jul 2012 Location: Mount Bethel PA Points: 941 |
Just finished planting today. 6 row planter with 70 series units.
Allis Express: Eastern PA on Rt 80
8050, 8010, 6080, 190, D14, DA 6035, AA 6690, 5650, Gleaner F2 |
Unit3 ![]() Orange Level ![]() ![]() Joined: 17 Oct 2009 Location: NC Iowa Points: 5598 |
Great pictures and stories, but I sure wish somebody had pictures and stories about the 24 row.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21919 |
The 24-row was a frame built by a company called CARMACO. A-C apparently teamed up with them on 12, 16 and 24 row frames. A ground driven planter unit was easy to hang on any frame and make it work.
1852 Moore Farm ![]() Bronze Level ![]() ![]() Joined: 21 Apr 2016 Location: Missouri Points: 91 |
Not sure where you are in Iowa, but i saw a four row Allis planter on Craigslist southwest of Maryville, MO. $350...good luck.
Daehler ![]() Orange Level Access ![]() Joined: 23 Nov 2010 Location: Lexington MO Points: 1160 |
Using a 6 row and a 12 row 385 on carmaco bar. Looking for a 24 row if anyone knows where one is. ![]() ![]() Edited by Daehler - 24 Jun 2019 at 6:35pm |
"IT TAKES 3 JD's TO OUT DO AN ALLIS, 2 TO MATCH IT IN THE FIELD AND 1 FOR PARTS!" |
darrel in ND ![]() Orange Level ![]() ![]() Joined: 22 Nov 2009 Location: Hebron, ND Points: 8720 |
I've been wondering if the 390 bar that allis hung 24 units on, would hold up to 24 of the deutz 385 units. Thus making a 24 row, 3855 planter. Darrel
Mike Kroupa ![]() Silver Level ![]() Joined: 02 Oct 2009 Location: pierce, ne Points: 337 |
There were several CARMACO planter bars in the late 80's that had WHITE Planter Units on them, plus fertilizer tanks. Not for sure where the local WFE Dealer purchased them from, but they held up fine. Both were 40' 16R30 units. HTH, Mike
Post Reply ![]() |
