Pto to transmission gasket
wisjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wisjoe Quote  Post ReplyReply Direct Link To This Post Topic: Pto to transmission gasket
    Posted: 04 Jun 2019 at 3:33pm
Hi. I have a question about the pto to transmission gasket. The lower 1/3 of this gasket is solid even though the opening it goes to isn't. Is there a reason that this gasket has all of the extra material on it? Should I trim the excess off? Does this gasket cover different options such as no pto? This is for a model C tractor. The one that I took off looks like the extra just wore away over time and it doesn't seem like having cork floating in the oil is a good idea. Thank you, Joe.
Just living the dream, with an occasional nightmare!!!
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2019 at 3:53pm
I believe it is to make a little reservoir to hold Fluid on slopes etcetera for the hydraulic pump. I could be wrong, that has happened to me once or twice in my lifetime.
Edited by chaskaduo - 04 Jun 2019 at 3:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote wisjoe Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2019 at 7:38am
That makes sense to me. Thanks for the explanation. I'm always learning something new about these machines.
