Allis 301
Fullpull View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fullpull Quote  Post ReplyReply Direct Link To This Post Topic: Allis 301
    Posted: 02 Jun 2019 at 8:27pm
Is it possible to put  the rear mounting plate from a Allis G262 onto a Allis 301 and the clutch/ driveline will lineup when motor is installed ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2019 at 8:44pm
Any thing is possible with enough time and money. But no to your question. 262 plate don't have square groves for sealing around frank and cam, plus bolt holes are different.
Guess you want to put 301 in D19 or D17?
Best would be to put 190 torque tube on D series or make adapter plate or redrill 301 plate to fit D series, then don't think 301 flywheel will fit into D series bell housing.          MACK
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fullpull Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2019 at 9:01pm
Does the flywheel from a 262 fit onto the 301 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2019 at 9:26pm
Yes, but is only 10" clutch.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2019 at 9:28pm
Sorry, D series is 11".    MACK
Larry W. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry W. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 12:51pm
Use the 301 backer plate and flywheel, it will bolt up to d19/d17 bellhousing. If using d17 gas, the input shaft is a different length then the diesel. The 301 flywheel and clutch will fit in as well, but will require some grinding in rear of bellhousing. if my memory is right you have to grind some in the starter pocket as well to clear nose of 301 starter.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fullpull Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2019 at 7:53pm
I am told the 301 is 3 inch longer, is that a problem with the rad on a D19
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fullpull Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2019 at 8:19pm
Looking for some more options, the Buda engine became allis chalmers then white/allis and then agco, so would the allis 301 fit into some White tractor or possible cockshutt 40 or 50 ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2019 at 7:01am
The Buda engine company was bought by A-C in 1953. Buda engines were continued with some redesigning to suit the A-C product line. The "301" (2000 series) and "426" (3000 series) were true new A-C designs coming out of the old Buda (now A-C) engine factory( Harvey, Illinois) in the early to mid 1960's. There is zero-zipp-nadda connection between these engines and anything ever used in a White/Oliver/Cockshutt.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2019 at 7:53am
a 433 (200 cu) engine from an F2 or 6060? 6070/80 should bolt up just like the 301 without the length issues.  same engine minus 2 cylinders
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fullpull Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2019 at 10:42pm
Thanks guys for all the information,this gives me alot to think about and possible lots of work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2019 at 6:52am
You haven't told us what you are trying to do. Makes it hard to give the best advice when we are in the dark as to what your goal actually is.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fullpull Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2019 at 11:55pm
Thinking of installing a A-C 301 into a d-19 or maybe cockshutt  35 or 40.
PeteMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeteMN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2019 at 12:22am
Quite a few things are different on the two motors.  The steering rod from a D19 won't clear the 301 motor.  The radiator ports are in different locations.  The throttle shaft is different.  Things like the tach drive are on the other side of the motor which means that they spin the other way.  You really need to park a 301 next to a 262 and start looking and measuring.  It can be done, but its not one of those projects where you just unbolt this unit and bolt in the other unit.  It takes quite a bit of modification so its just not practical.  Anybody with the skill to do it is better off doing something else with their time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2019 at 12:23am
BUT, if you are trying to make a puller out of it, you'd want the 6 banger not the 4 banger ……...
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2019 at 5:34am
It can be done. I've seen a 301 in a D17. A friend has a 301 in a WD-45 puller and his Dad just put a 301 in a D19.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2019 at 6:11am
I'd love to see pics of how they did the steering and does it have POWER steering on the D-17 and still look somewhat OEM. My project this Winter is going to be putting an F-2 four cyl turbo engine in a D-17 and the steering is my biggest problem. Would like to stay NF but may have to go WF with a steering ram on the tie rods like a late 170/175.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fullpull Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2019 at 6:36pm
What would need to be done to a A-C D19/262 engine to get to 100+ hp ?
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2019 at 8:08pm
Dads D19 dropped a sleeve many years ago. He took it to Reagan Imp in Hummeston Iowa to be repaired. When they got it back together and dynoed it, it was turning out 105 Hp. They turned the pump down to 75 Hp. Dad said "it sure doesn't pull the 5X16 snap coupler plow as well". What ever had been done to it was in the pump and he was using premium #2 diesel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2019 at 8:12pm
D-19 gasoline tractor when tested at Nebraska Test in April of 1962, the maximum PTO HP measured was 72.63 HP.   There's really nothing you can do to change that. It was  finely tuned as well as the Engineers could tune it. If you swapped out the factory carburetor for the one from an early model "F" Gleaner or late model "C-2", you would gain 10 HP.  I imagine a carb from a 190XT gas might be a little bigger yet and I'm sure there are larger carbs than that. Other than raising compression, increasing bore and or stroke and changing camshafts, valve sizes, etc there isn't anything you can really do but install a larger carb and increase RPM's.
Edited by DrAllis - 15 Jun 2019 at 8:12pm
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fullpull Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2019 at 8:28pm
What kind of bore and stroke would be needed to get to 100+ hp ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2019 at 8:55pm
Stroke is almost out of the question with out a lot smaller rod. Cam is notched now for rods to clear.
Bore is almost impossible, because you get into head bolts. I bored a block out to a few thousands of head bolts. It held until pump belt rolled over. That is when it took the front of block out.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2019 at 7:04pm
I built a G-262 for a friend 30 yrs ago. We used D-262 pistons and shaved .200" off the tops to lower the compression a bit. We had the camshaft grind improved and started with a 190XT carb. Pretty sure we were at 100 HP @ 2500 RPM's and would run it 4,000 RPM if the rules allowed it.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fullpull Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2019 at 8:12pm
Did that cause any head gasket problems or would a 1/2 in. stroker crank be more reliable to get the same hp ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2019 at 8:30pm
1/2 " stroke would make journals almost too small.
No head gasket problems, they was oringed.        MACK
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fullpull Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2019 at 9:15pm
What was the compression on that, was that with stock head ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2019 at 9:22pm
No, it was aluminum head on alcohol 50 lbs boost 8-1 comp. To.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2019 at 10:08pm
My cranking compression pressure was 300-320 psi if I remember right.....this was many years ago. Had to use 114 octane racing fuel.  I used the thicker diesel head gasket to get the compression down to that figure with a stock gasoline cylinder head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2019 at 10:35pm
Sounds like peeing in the wind to get "big" power and have it live. Probably be better off putting your efforts elsewhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2019 at 11:10pm
That engine I built ran us for 6 or 7 yrs and then we sold it to someone in Minnesota and as far as I know it is still running in a puller.
