Partially Dead Voltage Regulator? |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12418 |
Topic: Partially Dead Voltage Regulator?Posted: 29 May 2019 at 10:41am |
Daughter's car, 2010 Nissan Maxima.
Last December, her battery was dead and stranded her. Felt terrible, as I knew her battery at the time was getting old. She was away at college. A new battery was put in at a dealer. About 6 or 7 weeks later, car is dead again, only had been sitting about 2 days. Towed to dealer where they ended up replacing that new battery. Strange, but happens I suppose. Now here about 4 months since then, battery dead again. For kicks, I put a voltmeter on it, read 2 Volts, so yeah, DEAD! I put a charger on it, it took a charge just fine, and in turn started the car just fine. Put a voltmeter on the batter with car running, rock steady 14.5V. Thinking now I had eliminated alternator / regulator as a culprit.... Obviously, something is drawing the battery down. So I hooked my meter up to measure DC current. There was a steady .25 to .26 amp draw, which seems high, though I don't know the "spec" on that (and have been looking! Check out the picture below. I should have taken a better centered picture, but this is a picture of the swanky connector on the positive post of the battery. Upper left had corner is the post itself, which I've cut in half with my mad photography skills. The ring terminal you see contains 1 heavy red wire. The small group of flex conduits you see to the right and deeper in are groups of small wires, with several small connectors that connect to the underneath side of the big swanky connector. So....I'm thinking that big wire goes to the alternator (and is spliced to the starter somewhere). If I disconnect that big wire, and put the meter in there to check current draw, I get about half of that total draw in that circuit (roughly .125 A) I get that there's anti-theft, computer, etc. drawing some current all the time, however, what would be drawing .125 amps through that big wire? Can anyone confirm that big wire only goes to alternator? Or? Even though it charges when running, still have a failing diode or something in the regulator? Can't see it being in the starter motor, as that would not see juice unless solenoid was energized (which would mean it's stuck on trying to start). Thanks for reading. ![]() Edited by Tbone95 - 29 May 2019 at 10:44am |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35678 |
Posted: 29 May 2019 at 11:28am |
Whomever installed that "Bad" battery needs to perform a BETTER voltage drop test and Find the Problem, the one they failed to find the First time!!
Tbone95
Posted: 29 May 2019 at 11:56am |
Well, that would be nice, but that's over 250 miles from here. They don't "owe" me a lot in my opinion.....The battery replaced in Dec was old enough to warrant replacement. They then replaced that one under full warranty.
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2720 |
Posted: 29 May 2019 at 1:53pm |
I was talking to my neighbor yesterday about his mother's 2006 Nissan. Less than 40,000 mi. Same problem with batteries. I understand it is a wide spread problem with Nissans.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25255 |
Posted: 29 May 2019 at 3:42pm |
OK, drawing a 1/4 amp even 1/8th amp 24/7 WILL kill the battery..... I'd have to see a real wiring diagram but as you said there are several 'devices' always on even though the key is in your pocket. Being a fairly new car you'll have alarm system, radio, GPS and/or ONstar, infotainment system, remote start system, wirelss door entry wouldn't surprise me the engine computer is 'on' a bit either. If there's an 'insurance black box' in the OBD-II port that draws power 24/7 especaially when reporting to 'them' every so often. A bad diode in the alternator will draw power and kill the battery. Probably 50-100 fuses in the car....if (IF) you pull them all including the 'mains' you should not be drawing any power. Without the wiring diagram it's hard to say what is the power demon though. Jay
Tbone95
Posted: 29 May 2019 at 4:43pm |
jay, the car has some of the stuff you mentioned, not all, but really it’s irrelevant because for nearly 10 years the smarts of the car were smart enough to manage any and all of that. Obviously something has changed.
I agree that even 1/8 amp is still too high. I would have felt a lot better if I had unhooked that big wire and 200 out of the 250 had dropped! Half tempted to put an alternator in it. Still be cheaper than a service from the dealer, and if it didn’t help I’d have a spare for when it does puke. Seems all they’re going to do is throw parts at it too. To be clear, I removed and replaced each fuse one at a time, didn’t remove the whole lot of them at once. Unless there’s a third box of them somewhere, I did them all. |
jaybmiller
Posted: 29 May 2019 at 4:50pm |
well it wouldn't surprise me if there's a 3rd box... my 97 F-150 has THREE boxes of fuses.... You might have a corrosion whisker on the backside of a fuse panel. I know certain Dodge trucks have that problem...it actually eats away the stamped conductors in the 'fuse box'. Jay
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 02 Jun 2019 at 7:47am |
Remove the connections at the alternator and see if the draw goes away. If it goes away I would replace it.
1957 WD45 dad's first AC
1968 one-seventy 1956 F40 Ferguson |
allis g
Joined: 10 Jan 2012 Location: Templeton Points: 415 |
Posted: 02 Jun 2019 at 8:40pm |
Wife’s volvo draws power all the time we put a maintainer on it when parked in the garage. It’s a fun car for us so doesn’t get driven much
