Have to Confess
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: Have to Confess
    Posted: 29 May 2019 at 8:36am
OK, it is probably or might be mostly My fault with MO rains. Everytime weather starts getting pretty I break out the shorts, next thing I know the Sun hides behind clouds. So unsure if Sun is embarrassed NOT bright enough or just shading its eye as to MY white Legs and that I need to invest in spray on Tanning!!!
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 9:41am
Well that's mighty gentlemanly of you to try and ease some of the burden Ol Shammers carries on his back from that blasted machine of his. With that said wouldn't manure be a more Eco Friendly, Organic, and Frugal way to go than Tanning Spray. It would also piss off "A.ll O.ut C.razy" cause the weather would normalize.
Maybe I should keep my thoughts to myself. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 10:02am
BUWAHAHAHAHAHA~~~
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 10:57am
Shorts seem to bring out the rain in NWPA too. Didnt know that was causing it! Thanks for the warning!
FloydKS View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 11:16am
I have been wearing shorts on my bicycle rides (exercize in the open air) so maybe I have been contributing to the 'high humidity' too...
This page was generated in 0.664 seconds.
