Finally mowed some hay
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: Finally mowed some hay
    Posted: 27 May 2019 at 8:11pm
7EDF-44E3-B498-
A40FDE37356E.jpeg" />
Took a chance and cut one of our Orchard grass fields today. Forecasters have been wrong all weekend so I took a chance with their 20 percent chance all week. Hay is 3 weeks over due. Felt good to mowing on the XT pulling our AC390 haybine. Big brother on the 6060 pulling the Enorrossi 4 basket Tedder.
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2019 at 8:14pm
So tempted.
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2019 at 8:24pm
I see your tedder is almost identical to the one I bought this year. The only difference I see is the hydraulic tilt adjustment. Mine has a hand crank. It's the only reason you have to get off the tractor. Did you rig that up yourself?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2019 at 8:45pm
No, that’s the way we bought it new 2 years ago. May have been an option I guess. Really nice to adjust it from the seat. Have been really impressed with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 7:23am
I believe all I would have to do is remove the crank and replace it with a short hydraulic cylinder. That might be something I'll do later on. I really liked mine. It runs real smooth, doesn't shake, vibrate, or make any noise. It spreads the hay nice and even too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 7:36am
AC720man,
 Great pictures! I can almost smell the fresh hay curing! All nice shots of you folks and equipment working the fields! Thanks for taking the time to post!
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 12:47pm
Nice looking equipment! Thanks for the pix. Nice to hear that someone is getting into their fields.
WC, CA, D14, WD45
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 1:31pm
Yes it should be easy. I can't imagine using a crank as I fine tune it as I go.
It is a very nice unit and has dropped the drying time a lot for us.
Seems to be better built than the NH units
Charlie
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 3:00pm
Sweet pics Thumbs Up
Wink
I am a Russian Bot
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 3:02pm
Is a 390 just a Hesston PT-10? Sure looks like it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 9:21pm
I would have to say no. Pto runs through the tongue on the Hesston. Driveline to gearbox is totally different. Good question though. Tiger teeth on the cutter bar made a big difference for us. Orchard grass was almost 5 ft tall with blade grass about a foot tall. Cut it with no problem.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 10:41pm
Wow, great pictures.  I wish I could cut hay now, well, I could cut it but it might take two weeks to dry.  Looks like we have potential rain every day for the next two weeks.  Usually this is the driest part of late spring early summer.  I once owned a JD 9' swather that I heard was made by Hesston, boy, was that a piece of junk.  I guess I should have expected that, it was painted green after all...
Allis Express participant
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 5:24am
I've never owned a PT10. A 1090 and a 1091. The head and the right side safety shield look identical. The walking frame knife drive would make it for sure but its not visable.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 6:47am
Nope it's all Allis. Designed and built by Allis. They were good machines. Dad bought one in 1977 in like new condition and we used it for 30 years on our dairy farm. It out cut the old 460 New Holland we had and was a little simpler........ not as simple as later Hesston or New Holland but not bad. The rubber roller will never wear out but you had to keep an eye on the wobble box for oil and making sure the mounting bolts for it were tight, real tight (use loc-tite).
Wink
I am a Russian Bot
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 6:51am
I'd guess likely made by Owatonna as Deere was buying haybines from them for a while. The haybines were definitely junk.
Wink
I am a Russian Bot
exSW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote exSW Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 7:05am
Had an Owatanna(990???)one season. Pretty crude.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 9:25pm
Was able to bale some nice Orchard grass this afternoon after work. Threatening sky’s but no rain. Wife did well for her first driving experience. Our son joined us when he got off work. That’s him on my new to me WD, pulling the last windrow away from trees so it will dry for tomorrow. Ole girl with a foot throttle makes it a joy to rake with.
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 10:12pm
Did some hay today too sorry to hijack. If someone can post picture feel free too
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2019 at 11:04pm
Nice setup you have
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2019 at 9:57pm
You have a good looking fleet there. Thanks for keeping A-C alive, hard at work and on the job. Much appreciated!
