Muscles around the Knee swelling??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Muscles around the Knee swelling??
    Posted: 27 May 2019 at 9:32am
Guess I'm getting a little older, and this morning I woke up with the Gawd awfullest swelling around my left knee, just out of the blue? Had trouble with my right years ago but that went away, anyone experience this and on I of a home remedy? Try to stay away from the saw bones!
Edited by DougG - 27 May 2019 at 9:41am
trace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trace Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2019 at 12:11pm
ice 20 minutes, off 20 minutes. active on
or similar wrap with ace bandage.
1955 WD-45 WIDE FRONT W/ TRIP
LOADER
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2019 at 12:15pm
Welcome to old age, gets better(worse) as we go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 12:50am
hope it ain't a blockage!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 9:25am
Me too! probably arthritis and bercidus
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2019 at 2:09pm
Part of the Golden Years. Hope it's getting better. Prayers
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2019 at 7:29pm
Get some DMSO gel with Aloe Vera.
That should help.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2019 at 9:05am
Advil for 5 days. Use heat after 48 hours.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2019 at 12:02pm
Doug, if I remember right you run a crane for a living if the is right I done the same for a number of years and my feet and legs would swell up and my hips would also bother me have looking into I came up with if being lack of blood flow and would wear compression sock at night when I was sleeping to help with the blood flow I still have to wear them sometimes and haven't run any equipment full time for the last 20 years I'm not saying that is what is going on with you but if you sit day in and day out its does raise hell with the lower parts of the body over time. HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2019 at 6:37pm
That's very true Kenny,, im in a crane a lot , don't stay active in them !
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2019 at 6:48am
Take breaks,get out walk around. I know the argument that your job won't let you ,do it for your own health! There are supplements that can help along with excersise. My cousin before he retired from sales would drive from Elkhart Indiana to New York straight thru only necessary stops and his knees used to swell then he got a blood clot which worked it's way to a lung! Dr.told him 15 minute break every hour with stretching and walking. He learned Tai Chi stretching excersise and is now in his early 70's and healthy!
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2019 at 7:25am
Mine does that every now and again. Hurts right now some. Swells up some. Lasts a week to 10 days. Wife has some Diclofenac topical stuff to rub on it. Helps some.
Mainly just ride it out.
I had bone surgery 6-7 years ago right above that knee. Drs. at the time said I had arthritis in that knee. Said I would have to get it replaced eventually. They put a titanium plate in there about 8" long and is held in with half dozen screws. Weird to look at on an
x-ray.
Chananain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chananain Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2021 at 5:19am
If I were you, I wouldn't waste time asking questions on forums and immediately consult a doctor. As for me, any such change in your body should be directly indicated to your attending physician since it is not always as harmless as it seems. There is nothing more dangerous than an external change in the state of your body because something serious may be hiding behind it. If you don't think it's so serious, I could advise you to introduce more magnesium into your diet, as it is a perfect vitamin for your knees and your skin condition in general. I order all supplements on https://rats.army/. I hope you will be all right, good luck
Edited by Chananain - 05 Oct 2021 at 5:45am
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2021 at 6:47am
I am with Chan.  Hopefully through the years you have gotten hooked up with  trusted and worthwhile "saw bones"
Or give it a day or two first as long as it doesn't get worse.
Anyhow i don't think this is a job for the keyboard here.  Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2021 at 9:29am
well its been 2- 1/2 YEARS since he had the problem... HOPE it is not STILL GOING !! Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2021 at 10:40am
As much as you probably don’t want to hear it, time to see the doc. I battled knee pain for about 9 months and finally gave in and found out it was a torn meniscus. Been off work for 6 weeks, finally get to go back today.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2021 at 6:51am
Yeah, somebody had their spam for breakfast again!LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2021 at 6:15pm
Above is an example of a spam post.  Note low post count of the replier, age of the post, and the included spam link, in his post.
SPAM, REPORTED
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2021 at 6:00am
Happened to me last January. MRI showed torn miniscus, arthritus, and something else. Had to stay off it for over a month. Doc gave me a shot directly into knee cap area. Have been fine since.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2022 at 10:50am
Originally posted by koldobrew koldobrew wrote:
I've been having issues with my left knee for a while now, too. It's not that bad, but it's still pretty annoying
Wink So which of your Allis tractors cause you the most pain in getting on? An welcome if you are a tractor nut. or so long if your just looking for trouble. Cause we already have a guy making trouble with his snow maker "pretty machine".LOL
Edited by Ray54 - 14 Jul 2022 at 10:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2022 at 12:38pm
why would anyone open a 9 month old thread to add a post that contributes nothing ? ......... there must be another reason .
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2022 at 12:54pm
Well since someone brought it up, I recently had a similar issue. Right knee. did something I am not aware of or age. Wellness coach today said RICE treatment. Rest, Ice, Compression, Elevate.
Edited by plummerscarin - 14 Jul 2022 at 12:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2022 at 4:22pm
BOTH my brothers are dealing with this, older one had a DVT to EXTREMES, clot MRI'd at over 7" in length, he is STILL recovering, at seven months later.  Younger brother started having leg swelling and pain issues, going to see a Orthopedist this next week, was forewarned are classic symptoms of a Deep Vein Thrombosis, DVT.  BOTH Had Moderna Covid shots(the two) with Moderna Boosters.  I had Pfizer two shots and DONE.
Edited by DMiller - 14 Jul 2022 at 4:22pm
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2022 at 5:49pm
I have a bum knee and get swelling quite often.
I’m starting to have a bit of trouble with the good one swelling on occasion.
Sounds silly but my wife got me some of those copper fit knee braces and compression socks. They both seem to help.
Wife wants me to get the bad one fixed.
I’m waiting as long as possible.
And working on being debt free first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2022 at 6:02pm
Thad, i think MOST doctors try to put  knee replacements off till you retire..  They think that after 65 years old, your "activity" and "bending" will be drastically reduced .... If they do the knee when your 55 and the "SOCKET" has a 25 year life and you use it too much... you may need another "rebuild" before your 70. !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2022 at 7:35pm
Hoping to make it that long.
They have mentioned scraping out the arthritis in my knees and back hoping it may ease the pain a little and help prolong surgery.
This page was generated in 0.124 seconds.
