Does anyone know about water filters?
Liam684 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Liam684 Quote  Post ReplyReply Direct Link To This Post Topic: Does anyone know about water filters?
    Posted: 27 May 2019 at 5:56am
My father constantly works on a tractor and I noticed that he takes on bad water to work. He started having health problems. Nothing serious, but if he continues to drink this water, he may have problems.
I want to help him, but I have no experience in the purchase of such things. My father in the tractor has a small tank for drinking water, I think to put a filter in it so that the water is filtered as necessary and install the second filter to his home.
What do you think about these options http://https://wisepick.org/best-water-softener-system/? If you have other options or tips, please let me know, this is important, you need to resolve the issue as quickly as possible.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2019 at 6:32am
Probably best if you move this topic to the shop barns varmints and trucks section. Someone is more likely to see it there and have a suggestion.
Allisplumber View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisplumber Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2019 at 8:24am
You should have the water tested for bacteria if it is a private well first, if he is not regularly washing out and sanitizing the tank he is keeping the water in with chlorine, it probably has bacteria growing in it , no filters will take that out , sanitize the tank with chlorine and see if things get better?
