D17 WATER IN TRANSMISSION
jeickman01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeickman01 Quote  Post ReplyReply Direct Link To This Post Topic: D17 WATER IN TRANSMISSION
    Posted: 26 May 2019 at 7:34am
D17 Series 3 is getting rainwater in the transmission.  Thought I had this fixed when I replaced the shift lever boot.  Fills to the point that it leaks out past the rock shaft seals.  All my manuals are in storage so I need help.  What are all the places water could get in?  Boot, breather, shift cover gasket, rock shaft seals?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2019 at 9:21am
Breather and the gear shift boot are the only places where water could possibly get in.  Are you sure it's water?  Very common to have hydraulic oil migrate into the transmission through the input shaft seals.
Best way to keep water out is to park her under a roof.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeickman01 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2019 at 3:38pm
I was hoping you would reply.  It's water, oil is milky white.  But since I posted I remembered that when I bought the tractor I noticed that someone had R&Rd the rockshaft housing and that here was ugly silicone smeared around the joint.  May have answered my own question.
