Trying to ID this pto driven hydraulic pump on B |
ihscout
Joined: 12 Jul 2011 Location: Northern CO Points: 147 |
Topic: Trying to ID this pto driven hydraulic pump on BPosted: 22 May 2019 at 8:48pm |
There is no numbers, plate or identifying characters. Hoping someone can help me identify it.
'40 AC B - My Pappy always told me "Use your head for something other than a tack hammer!" I did. It makes a great 16 pound sledge hammer.
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Posted: 23 May 2019 at 8:48pm |
You know, This forum comes up with the damnedest things. I was fortunate to be alive through the life of the B but I have never seen this pump. Correct me if I am wrong but it looks like it is attached to the pto through a universal joint? Usually the B pump is attached to the rh side of the PTO - facing front. Could you give us a picture further back so I can get a better prospective. A real mystery. Thanks for sharing. Take good care of my favorite. Good Luck! Bill Long
ihscout
Posted: 23 May 2019 at 8:54pm |
Sure! I'm pulling it off the tractor tomorrow. I'll post other pics. Thanks
Tony.Or
Posted: 24 May 2019 at 4:16pm |
Have 2 big pumps like that on K crawlers. Lots bigger though .. Tony
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55304 |
Posted: 24 May 2019 at 5:55pm |
What does it run/power?
ihscout
Posted: 24 May 2019 at 6:41pm |
It powers a front end loader
ihscout
Posted: 24 May 2019 at 6:42pm |
Hey Bill I didn't get the pump off today. I'll post some pictures tomorrow though when it's off or Sunday
Bill Long
Posted: 25 May 2019 at 1:57pm |
You know, I think DiyDave may well have hit the nail on the head. It powers a loader therefore is an after market pump. Yes, it probably runs off the B PTO and is mounted on the seat. Since the loaders require much more oil flow then the B AC pump produces this was added. Thanks Dave. Correct question. ihscout, Check the make of the loader. Going there - if still in business - may provide answers you need. Again take good care of my favorite. Good Luck! Bill Long
Tony.Or
Posted: 25 May 2019 at 3:46pm |
Got out & scraped on Pump on WK Crawler . Hydreco brand pump . 1.5" lines coming in & OUT. WK had a c frame bigger than the one on my HD6 EP. Must have had a 12' blade . was told they used it to push snow near Grants Pass Oregon.
My K is set up similar only it looks like it was farm crawler .. Tony
ihscout
Posted: 26 May 2019 at 1:17am |
I couldn't find a tag or anything on the loader either. The problem was the front seal was leaking horribly and I've had it apart before. Guess I used the wrong substance to repack that front seal so this time it's fixed for a while longer. I used a couple of those plugs that you use in a tire patch kit and wrapped them around it, tighten the seal nut and have run it for about 4 hours with no problem. Thanks all for your input
