WC Rearend Bearing Numbers?
NCWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCWC Quote  Post ReplyReply Direct Link To This Post Topic: WC Rearend Bearing Numbers?
    Posted: 03 Aug 2010 at 9:30pm
I need to know what the bearing numbers, and the seal numbers are for the outer top drive shaft in the rearend of a WC. Went to take the wheel off and heard it roaring and knew something was bad. Got the lower bull gear off and the ball bearings from the top fell out on the ground. Got the brake loosened up popped the shaft out and the inner seal in the brake housing was toast also. If anyone could save me the trouble of taking the other side apart to try to find bearing numbers it would help alot.
Thanks!!
B,C,CA,RC,WC,Unstyled WC,WD,WD-45,B puller, WC Puller,WD Puller, WD-45 Puller
Jeff(WC)(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2010 at 10:58pm
i just replaced that ball bearing...but not the seal...i will get ya the bearing manufacturer and number tomorrow that it crossed over to...if i forget..PM and remind me
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2010 at 8:16am
I had no luck finding an aftermarket seal for my unstyled but I limited my search to a half tank of gasoline.  I ordered it from AGCO, part #70202602.  The new one doesn't look like the old one, lots thinner but works.  As for the bearing, if you are talking about the big ball bearing the original is a New Departure 1309.  New Departure is long gone but any bearing place can cross it, expect $100 for it.  There is an AGCO dealer or so that still have one.  I found one on the internet, new old stock, don't really think I needed it but since I bought it its on now.  That bearing is sheilded on one side, a 40 degree angular contact, 45mm X 100mm.  If you have no luck let me know, I will send you the one I took out, I believe its good, just needs to be cleaned as its sit around in the shop since removal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Aug 2010 at 9:23pm
Took the other side apart last night, found a good seal name and number;  National  50094
Forgot to put in that this is on the seal.
Edited by JW in MO - 19 Aug 2010 at 7:33am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 6:55am
darn it i forgot to look...do you still want the new name and number that mine crossed to and fit like a glove?
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 7:52am
Jeff - always nice to have that sort of information for all the unstyled WC owners (like me) on here! Thanks in advance.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 8:28am
i hope it's not different on the unstyled...mines a 41 styled
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2010 at 4:23pm
finally got it...my original was a new departure 1211...it crossed to an ORS #211N  they are made in turkey....got it from bearings limited through one of their distributors...hope this helps
Edited by Jeff(WC)(MI) - 21 Aug 2010 at 4:24pm
This page was generated in 0.240 seconds.
