Replacement 8050 radio
7010 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7010 Quote  Post ReplyReply Direct Link To This Post Topic: Replacement 8050 radio
    Posted: 21 May 2019 at 11:56pm
I only have a am radio in my 8050,  can anyone help in how to get a am/fm radio to replace this one with?  I would like a original if possible?  Maybe a salvage yard?  Any help would be appreciated. Thanks
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 12:19am
Put an add in the classifieds?
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2019 at 6:28am
So, I have been modernizing my 7010 cab and I pulled the radio out of the cab.  I am not convinced that this radio is original equipment because it was in the wrong slot in the cab.  The 7010 has a radio slot and a tape deck slot.  This radio was in the tape deck slot.  However, it is FM and AM.  When I turned it on, it was definitely FM.  It also isn't a true stereo in that the only 2 speaker output wires are spliced to get the second channel.  The other issue is there is no way to know if your antenna connection will fit this slot in the radio.  I can see the standard antenna on my 7010 is different than modern antenna slots.  Here is what you should do regardless if you want mine or not.  Measure your opening from center to center of the knobs, measure the box size to insure a new one will fit, measure the antenna hole and post those measurements.
You can buy vintage radios for old cars that may fit, but they are in the $200-$300 range.  You will have bluetooth and all the modern features if you go this route.  Antenna may still have to be replaced.  If you are electrically inclined, you can buy a circuit board for about $15 and hook it up.  If you go this route, you might as well replace the speakers because AM only radio would not have nice speakers.
I actually went with a Pyle 2 channel marine bluetooth amplifier with no radio receiver because my son primarily listens to his phone and the phone has fm radio too, and no need for an antenna.  This allowed me to avoid the fit issues.  Hope to finish this by the weekend.
Like every upgrade, things get out of hand if you do them right.
I would sell my am/fm radio for $20 plus $5 shipping.
80 7010, 80 7020. 67 190XTD Series I w/500 Loader, AC 2000 Plow, AC 4 row Planter, AC 77G Rake, Member Indiana A-C Partners, Member TAC
