Woods L59 flat idler pulley
archangel_cpj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote archangel_cpj Quote  Post ReplyReply Direct Link To This Post Topic: Woods L59 flat idler pulley
    Posted: 19 May 2019 at 4:31pm
Woods L59 on an 39B and the flat idler pulley is toast... What size is that I need to order a new one???
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2019 at 5:01pm
I don't recall the size, but I measured the diameter and width and bought a generic pulley/ bearing unit at the local Farm Store a few years ago.
Depending on the model, I have also drilled out the 6-8 rivets holding the two sides together, pop apart and replaced the bearing... then use small bolts to bolt the pulley back together....... cheaper.
Edited by steve(ill) - 19 May 2019 at 5:03pm
