Locked up 7040 |
joelsplace
Joined: 07 May 2019 Location: Northlake TX Points: 74 |
Topic: Locked up 7040Posted: 17 May 2019 at 9:17pm |
Well I should have tried to turn the crank before I did anything. Engine is locked up solid. Pulled the exhaust manifolds and found a rusty coating on top of the carbon. Pulled the intake and a little water ran out. I'm guessing the cylinders are rusted up.
1975 7040 w/Power Director
joelsplace
Posted: 17 May 2019 at 9:19pm |
I've got the top stripped down to the head. All the obvious head bolts out but it won't budge. There aren't more head bolts under the plugs in the top surface of the head are there?
MACK
Posted: 17 May 2019 at 9:27pm |
Did you remove the rocker arms? There are six long bolts through rocker arms that hold the head down. MACK
joelsplace
Posted: 17 May 2019 at 9:40pm |
I did. I'm guessing it's just stuck?
DrAllis
Posted: 17 May 2019 at 9:41pm |
Long prybar on top of the A/C compressor and under the thermostat housing.
joelsplace
Posted: 18 May 2019 at 12:44am |
I already took the housing off but I can put it back. Thanks!
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5205 |
Posted: 18 May 2019 at 8:27am |
there's 26 head bolts. Make sure you have them all out before using force. Once you are sure they are all out, then some force will be required.
joelsplace
Posted: 18 May 2019 at 8:36am |
Thanks for the count. I'll check.
