What does this part fit?
Ross D. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Topic: What does this part fit?
    Posted: 16 May 2019 at 11:29am
I found this part in a misc. box of L & G items. It says:
   Allis Detuz - one 72969269 - 8 L.G.
   Kohler package,   KKK,   Paw-0480
   Stator.
   Ross.
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 9:27pm
It is a stator for K-Series Kohler single cylinder engines with I believe the 3 amp unregulated charging system. Most used a stator that was a "full round" and was more around 15 amps and had a separate voltage regulator. Some of the AC 700 Series used this smaller 3 amp stator. Due to the lower output it did not require a regulator. Thats what my 1977 model 710 had. This was designed only to give enough output for a lighting circuit but not enough for an electric PTO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 10:35pm
Take another look at the AC number on the box. Could it possibly be 72068249 ?
Edited by ACmowerguy - 17 May 2019 at 10:37pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2019 at 11:31pm
Got it. Original number is 72069269 and the Kohler number is 45 085 02
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 7:27am
Good morning Chris.
   Thank you for the reply. Just to confirm the numbers:
   Does this help? I appreciate your help.
   Ross.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 7:51pm
Yes Ross. Thats the same number.  Crosses over to Kohler 45 085 02
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ross D. Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2019 at 10:10am
Chris.   Thank you for your assistance. It is appreciated.   Ross.
