styled/unstyled
mhankins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhankins Quote  Post ReplyReply Direct Link To This Post Topic: styled/unstyled
    Posted: 15 May 2019 at 8:57am
Keep seeing references to styled tractors.
 What designates this?
eryanh View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote eryanh Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2019 at 10:25am
I think typically unstyled is Pre-war, Styled is Post war.
1958 AC D17 Series 1 NF
1949 Farmall M NF
1938 AC B
CAL(KS) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2019 at 10:30am
In 1938  wc sheetmetal changed  and would be basically the same through WD and WD45 series tractors with the rounded radiator guard and streamlined hood.  earlier wc had only an optional radiator screen, radiator was visible, hood was very simple and gas tanks were not tear drop.  Fenders changed.  WF went through similar changes.  Model B started in 38 started out with the styled look.  I think the changes were to to modernize the wc  with the introduction of the B
U and UC tractors were never styled but did have changes early on in sheet metal
Edited by CAL(KS) - 15 May 2019 at 10:34am
HoughMade View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2019 at 11:04am
Styled have sheet metal covering the radiator, a grill shell.  Normally the lines of the grill shell flows into the hood and there are some sort of curves in the profile.
Unstyled have a cast radiator without a sheet metal cover- no grill shell.  The hood meets the radiator directly and there are mostly straight lines in profile.
Edited by HoughMade - 15 May 2019 at 11:06am
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhankins Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2019 at 8:05pm
Thanks
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2019 at 7:17am
Us and UCs did have a cast radiator but the unstyled WC/WF did not have cast radiators. Their radiators were brass.
This page was generated in 0.127 seconds.
