weights , Brianahart.net , lbs.
steve fischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve fischer Quote  Post ReplyReply Direct Link To This Post Topic: weights , Brianahart.net , lbs.
    Posted: 14 May 2019 at 8:46am
I use brainahart.net to look up weights casting numbers , would be neat if he could list how much they weight also and I have others not listed how to get them on list
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 1:49pm
Search for Brian Ahart on the member list, and send him a message.
frnkeore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 3:13pm
It would be nice to have a thread, where everyone could post weights and casting numbers. I have a set of MF17's that I'm putting on the outside of my D17. They weight 390 lb EA, 4 bolt, 14 3/4 bolt circle.
I assume the 17 means 170 KG. 170 KG is 374lb
It would also be good to know the number and bolt spacing of weights.
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
joelsplace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joelsplace Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 5:58pm
What do the front 7040 weights look like?  I don't have any.  Numbers?
Brian Ahart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Ahart Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2019 at 8:22pm
Steve,
I'm glad that you and others have found the site to be helpful.  As I've mentioned before, I started the Weight ID section on my website as a way to catalog the weights in my personal collection.  Thanks to photo submissions by others, the content has continued to grow.  When time permits, I would like to add additional information such as weight (lbs), and expand into aftermarket weights.
If you have any factory A-C weights that I do not have listed, send me a PM with photos and I'll be happy to add them.  I always credit those who submit photos.
A-C Weight ID reference and other goodies at brianahart.net
