WD-45 Water Pump Bypass Pipe
Prairie Homer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Prairie Homer Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 Water Pump Bypass Pipe
    Posted: 11 May 2019 at 6:39am
My water pump replacement isn't going to set any world speed records. Is there a replacement by-pass pipe available or are folks heading to the hardware store for some plumbing?
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2019 at 9:41am
get short pipe fitting then use later hose that has the curved end put fitting on pump the latter wd45 had that from new agco  70227018 hose or after market steiner # acs2248
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2019 at 4:27pm
WD45 water pump bypass Yes I have a 1954 WD 45 with a WD motor would that pertain to that year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2019 at 10:40pm
If it's got the 45 water neck,the curved end hose will work as bypass to nipple in water pump.
