ford ranger no start
trace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trace Quote  Post ReplyReply Direct Link To This Post Topic: ford ranger no start
    Posted: 09 May 2019 at 11:27am
i know this is off base but a lot of mechanical knowledge on here. about a month ago i had my mechanic change the valve cover gaskets on my 99 ford ranger 4 liter 6 cylinder. ever since when it's wet out it won't start. turns over fine but no fire. i took it back and it set at his shop for 5 days but would always start. rained yesterday and wouldn't start again. dried up this morning and started fine.??? any suggestions??? have had this truck for 11 years and has never failed to start. 205,000 miles and just a work truck but love it and want to keep it.
1955 WD-45 WIDE FRONT W/ TRIP
LOADER
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 11:46am
Distributor cap cracked?  Rotor corroded?  Replace plug wires?
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 12:44pm
Shameless must not have seen your post yet or he would have had a suggestion for you...
Allis Express participant
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 2:11pm
Na it's just over his head
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 2:40pm
  Yeah,,,and his suggestions ain't gonna be anything nice bout fixin it ,,,,,just you wait,,,,,Wink
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 2:53pm
You might try a water bottle and mist the plug wires and distributor cap while it is running to see if it starts to stumble.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Manchester Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Manchester Allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 2:53pm
I will second the ignition related response.  Usually a moisture related no start comes down to Spark plug wires.  Can also be dist cap, but I believe a '99 has the ignition module with the wires plugging in there.  Easy test when it is dry and running, use a spray bottle with water and squirt the area of the spark plug wires,  if there is an issue you will get a good light show.
Post Options Post Options   Thanks (0) Thanks(0)   Quote trace Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 3:22pm
thanks guys. that's what i mean, wealth of info on here. it is a coil pack. appreciate the help.
LOADER
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 7:42pm
Not positive, but I was thinking that they have coil packs in them. 98 explorer does, and that was the first thing that went out on us.--developed the might start, no start thingy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 8:06pm
ya'll already know what i'd say on this...however...me being the nice guy I is, I had a Dodge that would do the same thing until...one nice dry day I bought a can of spray sealer, and sprayed the entire cap and all the plug wires with it. had to do it about twice a year, but it solved the problem. cheap and easy.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 9:11pm
I had a f350 do the same thing. Never did figure it out. New caps and wires didnt help. What with all the carb problems, I just sold it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 9:23pm
Ain't he just the sweetest you ever seen,,,,??? er,,,,,,,,maybe he is changin a little at a time,,,,,??ClapClap
  You allright,,Shameless,,,,and,,,and,,,I'm gonna tell ole JC and Chask to not poke you so much,,,UM,,,at least no more than a couple times a day,,,,,,LOL
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 10:56pm
Where have I heard that before? LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 9:33am
Dang it, I even googled ‘99 ranger distributor cap before I posted, got hits showing 4 and 6 plug wire terminals. I thought google knew everything.
Post Options Post Options   Thanks (0) Thanks(0)   Quote trace Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2019 at 8:44pm
ok guys, sprayed water on coil block and plug wires, nothin. open to more suggestion from you. thanks.
LOADER
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2019 at 7:37am
A shot in the dark here, did he get a wire pinched under the valve cover? That happened to me on my old '74 Plymouth. In my case the alternator stopped charging after I put new valve cover gaskets in it. Found there was a little wire that got pinched under the cover when it was tightened down and it was intermittently grounding out because the insulation was cut through. Not likely in your case but anything's possible.
This page was generated in 1.219 seconds.
