D15 governor
1947WC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Topic: D15 governor
    Posted: 08 May 2019 at 1:53pm
The governor on my D15 jumps up and down in a pull at high RPMs
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 3:46pm
Did it just start doing this when in the past it didn't ??? A carb set too lean can do that. Removing the carb and replacing it can change the linkage synchronization a bit. What's the whole story ??  Series 1 or 2  ??   There is a surge screw on the governor that could be tweaked a bit. The link rod between the governor cross arm and the carb could be shortened 1/8" of an inch. Governor linkage rubbing or binding can cause this...……..
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1947WC Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 7:09pm
Thank you so much Dr Allis
This page was generated in 2.273 seconds.
