Planter Speed?
Garrett2006 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garrett2006 Quote  Post ReplyReply Direct Link To This Post Topic: Planter Speed?
    Posted: 08 May 2019 at 4:11am
At what speed should I be running when using a 2 row Allis Rear Mounted Drill Planter? Also, what should I adjust the rear wheels to with the turning lever in center of the two planters? I guessing the planter should be setting fairly level? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 5:30am
No faster than a horse can walk.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garrett2006 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 5:35am
Thanks. What about adjusting the screw lever handle in center that moves he closing wheels up and down. Is there a certain spec that I’m supposed to be setting them to?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 5:40am
The operators manual for the planter explains how to set the depth with that crank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garrett2006 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 5:49am
Don’t have a manual. Hoping someone on here does that can explain it or knows from experience on how to set it.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 6:27am
4 mi. per hr.
1 1/2 to 2in. deep, depending on soil and conditions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garrett2006 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 6:52am
I have the skids thats Mounted onto and around the shoes to control depth, but needing to know where to adjust the lever that turns and raises and lowers the 2 wheels in the rear. I’m guessing this controls down pressure on the wheels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garrett2006 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 7:04am
I have uploaded & circles the part I’m talking about
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 8:50am
Don't see any circles or a part, ---I only see a rear tractor tire and a can lookin thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 8:58am
move the pic side to side....
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 9:23am
I have seen drill planters changed to three point hitch have trouble holding the right depth,
if you can hold the three point at the same depth after lowering it down every you lower it and yes that lever is how you can set the 1 1/2"/2" on the planter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 10:34am
I would think 2 1/2 to 3 MPH would be plenty fast for that age of technology...……...
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 11:20am
Growing up I worked for a farmer that had one mounted on the WD 45.  He ran it at a high throttle in third gear.  He said he could plant faster than anyone with a four row planter.  You could here it clicking off the drops and never missing a beat.  The corn always looked great.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 11:27am
Go slow.2 1\2 to 3 mph. Gear up. Throttle down. No need to be wide open. It pulls real easy.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 11:42am
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garrett2006 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 11:53am
Thanks for all the reply’s. Helps out out! Should I take the skids off the shoes & just use the lever for controlling depth or leave them on and set the lever at max depth? Thanks for the picture out the manual as well!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Garrett2006 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 4:14pm
Do you happen to have a picture that will show and explain the gears? Planter worked great, but may want it to space the seed little closer than it is now. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 6:04pm
Rule of thumb is the bigger the driver gear is or the smaller the driven gear is, the faster the shaft will go...
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 7:31pm
Measure the circumference of the planter wheel and give the wheel one turn, catch the corn and divide  that into distance traveled and that will give you the seed spacing.
ehuey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ehuey Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2021 at 8:55pm
The rubber on the tires look new.  Where did you get those done?
Wispitfiremike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wispitfiremike Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2021 at 9:41pm
Whole machine looks good and it sounds like it works well too, would think not easy to find someone to put that rubber on wheels.
