My old GMC
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: My old GMC
    Posted: 07 May 2019 at 9:23am
Still hammering on it. All hoses, belts and a Tune up on it. Now that winter is done can get to the Grain Sides off the old bed and get them out of the way!!
Best 8N/TO20 overhaul pics have seen in quite awhile!!! Farm Store Enamel and airless sprayer.
Still have to overhaul the grain gate.
Edited by DMiller - 07 May 2019 at 9:25am
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2019 at 2:37pm
Looking good
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2019 at 2:43pm
Thanks, not perfect but not gonna be either!! Will look good enough to haul stuff, will Not mind at all!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 12:26am
I wanna see the GMC
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 6:44am
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 7:38am
     Looks like your truck runs on propane? How does that work for you? Have a couple of local guys with compressors and use natural gas from wells on their farms.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 9:28am
Knew from working on them that will use more LP than gasoline, but not a heavy use machine in any sense. Then there is the aspect no gasoline to go sour and carburetor to dry out or gum up or diesel to algae out, Starts no choke regardless the weather conditions just have to allow to warm so the vaporizer can do its job before running it much. LP fill up was $83.00 for 73 gallons. Do have to buy a state highway tax sticker for alternate fuel at $100 one time fee, but STILL cheaper than gasoline.
Edited by DMiller - 08 May 2019 at 9:29am
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2019 at 7:02pm
Looks great!! Nice truck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 8:48am
Looks better today, still working on grain gate(cobbled mess) but closer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 9:17am
LOVE that truck!!
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 9:33am
Dave, many on here have now turned green, shame on you. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 12:03pm
Still need to find a good hood, that spot on it is a rust hole. Was a Beer truck at one point in life, had a nose mount refrigeration unit and drained water down into the hood incessantly, worked on quite a few as this. Runs and drives well, a little slow as geared for City but useable. Did JUST get done rehabilitating the grain gate, was just a bent up mess. Floats thru stroke well now, got the small feed supply door to function smoother and straightened out the lift arms timing as would twist and bind up.
Have a Upper spreader bar to clean up and paint then set the entire rear steel.
Edited by DMiller - 09 May 2019 at 12:09pm
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2019 at 12:40pm
Ive got a good hood I'd sell you real cheap but I'm not planing on heading east anytime soon.  It's even white!
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 2:05am
thanks for the pics...looks really good!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2019 at 6:24am
Thanks guys, been a project!! Thanks too John, I am not visiting CO for quite some time but may end up out there before end of summer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2019 at 10:29am
Got it all back together yesterday morning, was dreading trying to see if would all still fin up with repairs to bed frame new crossmembers and straightening bows in side panels. Also needed to show my straightener press, worked like a champ, just wide enough!!
Had to make two J bolt tie down bolts and made strap secured corner bolts and one handle nut assembly day before, paint was dry so assembled too.
May not be sand or Clover seed tight but good enough as a basic grain or feed truck.
Edited by DMiller - 11 May 2019 at 10:31am
