Porch Deck?
Gary(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Topic: Porch Deck?
    Posted: 05 May 2019 at 3:56pm
Wife and I had a porch deck built 15 years ago with treated lumber. We did not stain it then question is what would it look like if stained now? Should we just build a new one? Old one is solid just looks weathered. Thanks Gary
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 4:06pm
Power wash it. It’ll look like new. I stained mine last time around but only held up about 3 years. Time to do it sgsin
D17 Series 1
Allis B- 1939
Allis B- 1945
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 4:10pm
I just picked up deck stain at Sutherlands, color is cedar and am very happy with it. It actually looks better on older wood. I thought it was oil base until I tried to clean the brush with lacquer thinner to no avail, then I read the can that said use soapy water. If the wood is solid I would stain it because I just spent more than I wanted on a 15X 20 rebuild last fall.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 4:38pm
when you powerwash it  you'll NEED 2-3 days of warm,DRY weather to dry out the deck !! Be SURE it's really,really dry......BTDT..
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 6:14pm
Wash dry and seal. It will look good if the wood is still good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 7:12pm
Thanks guys. I hoping I could. Thanks for the good suggestions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 7:44pm
Our deck is 35 year old. It was stained and now has been painted with the deck renewsit material which is pretty good, but any of them need some maintenance. Yes I would powerwash and then see what it looks like. Use stain to finish. I need to replace the top board and am going to use man made material.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 8:33pm
To Chris and any others here the man made deck boards won’t span as far as wood. Make sure you read on the material before you buy and install on an existing deck. I’m not knocking the stuff but I have learned from experience that it won’t span like wood.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2019 at 8:42pm
I power wash then let dry a few days then spray on with a pump sprayer a concoction of 4 parts Thompson's Water Seal and 1 part boiled linseed oil.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2019 at 12:23am
my deck is 44 years old, still strong, we use Clorox on it and brush with a stiff broom, rinse it and apply a water proof stain. we also let it dry a week before applying the stain. when I built it, I used 2x10 in frame boards and 2x6 top boards. no sags in the framework yet
This page was generated in 0.118 seconds.
