Underlayment for metal roof
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Topic: Underlayment for metal roof
    Posted: 03 May 2019 at 12:31pm
My rental house roof is leaking and I've decided to remove the asphalt shingles and replace them with pro panel steel.  I have to replace some of the plywood under the roof as it has started to rot.  Wondering what you all think I should use for underlayment.  Seems like tar paper isn't in favor anymore as it doesn't seal to the wood well.  TIA
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 12:54pm
The Hy-Grade steel roof on my house has been on 12-14 years ? Install consists of strapping 2by3 vertically over existing roof( it was slid), then strapping 1x4 horizontally, then the steel shingles go on that. It provides a solid WELL ventilated underside for the steel. LOTS of air flow is necessary.
In your case, Once the mess is removed and repaird , I'd cover 100% of the roof with 'ice and water shield' or whatever it's called south of the 49th. The low pitch(3-12) addition was 100% covered then we put 3-4 layers of it at the 'valleys',each one bigger than the last by 2-4 inches.Not one drop has ever come into my house since then. I don't know what 'pro panel steel' recommends for air gap, but I'd suggest 2by4 vertically instead of 1x3s. Cost is not much more and  2by4 are better boards. Buy 16' one, better grade, at least up here, so less waste.
Jay
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 12:54pm
Up here we use ice shield on top of the decking and steel directly on top of that. that is current code for new residential construction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 3:49pm
What the installer was told here(no code) was 3/4" underlayment for steel or furring strips 1x3 or 1x4 at no greater than 32" intervals, Use a decent top cover on the plywood prior to the furring strip install. We have a sheet material called titanium paper under our roof.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 5:05pm
Titanium paper and similar is what they put under everything around here. I like it because if it gets rained on it doesn’t wrinkle up.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 7:44pm
On my 2/12 pitch I have ice and water shield on top of deck then the steel on top of that. Been on maybe 15 years and no leaks.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 9:31pm
hot tar it! lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 10:53pm
If you put the ice shield on the deck and steel directly on it youll have a very quiet roof.with a continous ridge vent you wont have condensation problems.
