200 pto problems
prbean View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote prbean Quote  Post ReplyReply Direct Link To This Post Topic: 200 pto problems
    Posted: 02 May 2019 at 12:56pm
200 PTO problems
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2019 at 1:04pm
That's a lot of PTO problems!LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2019 at 2:31pm
And problems are ? Is it hydraulic or manual engagement ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2019 at 3:44pm
Let's assume he has the manual shift PTO lever to the left of the seat. It sounds like the rear PTO shaft needs to be pulled out of the tractor and dress up the damaged splines with a 4 inch grinder. This will require draining the hydraulic/transmission/differential oils for a total of about 15 gallons of oil. If it is a 540 only PTO the shaft will pull right out after removing the three bolts holding the PTO shield. If it is a 540/1000 PTO you will have to remove the lift arm housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2019 at 4:23pm
What are you guys seeing that Im not ? I just see 200 pto problems
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 6:41am
Beats 201 PTO problems
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 7:24am
The other thread by the same guy with the same title.
Post Options Post Options   Thanks (0) Thanks(0)   Quote prbean Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2019 at 1:30pm
Is there a clutch that needs to be adjusted like on a 190xt just asking!
Post Options Post Options   Thanks (0) Thanks(0)   Quote prbean Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2019 at 10:31am
Still having problem with the PTO not staying engaged , guess need to drain the oil and pull the shaft again like Dr Allis  suggested  as I did last year and dress up the splines! Any suggestion would be greatly apprenticed Thank you in advance.PB
Post Options Post Options   Thanks (0) Thanks(0)   Quote prbean Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2019 at 10:35am
Its a 540 manual shift on the left side of the seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2019 at 11:00am
If you fixed it once,why are you having trouble again? You surely know not to grind it in gear?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2019 at 1:09pm
I have taken the shaft out on some 190s and ground the front end off a 1/4 inch or more and then ground the step back on the rear of the shaft where the bearing seats the same amount. This will let the shaft go into the housing further. As long as the seal has a good surface to ride on,you should be alright. Chamfer the front splines a bit to ease engagement. This should work on a 200 also. Crude but effective.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2019 at 1:27pm
Check the bell crank /pivot point on the inside of the PD housing, there are 2 ears on that thing where it connects the shafts together one maybe broke off, had that happen on a One Eighty once doing exactly what yours is
Edited by DougG - 11 May 2019 at 1:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2019 at 8:53pm
Make sure bolts have not come loose in transmission cover where lever is mounted. Don't ever remember seeing 200 jump out, a lot of 180-185. Have saw them ground so bad you could not shift them in and twisted splines.        MACK
