WD45
SD Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SD Allis Quote  Post ReplyReply Direct Link To This Post Topic: WD45
    Posted: 30 Apr 2019 at 4:00pm
I am thinking about rigging up a set of duals for a WD45. I am sure one of you members has done this. My question is, how or what did you use for a spacer between the hubs? Pictures would be helpful!
Thanks in advance
Warren
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 7:31pm
I run clamp-on duals on the WD45's, let's it stay on top  in wet ground.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 8:55pm
Mine came with duals when I bought it.  They are just regular clamp on duals from what I can tell.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 6:39am
There are lots of methods, but I think a set of clamp on T-rails is the easiest like mine and the above people use. My duals have a 10" spacer band on the dual rims instead of a more normal 8". I don't really like how wide they are but that's what I found for a decent price.
I have a set of unverferth eyelets that attach to the rails on the tractor rim. Then the J-hooks go through the dual rim and loop through the eyelet.
When you find some, make sure to run several PSI lower in the duals. You want your tractor tires to carry most of the weight. The final drives weren't really made for duals like a modern tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 7:25am
Discing moldboard plowed ground with duals makes a huge difference in the tractors and the discs performance. As a teen, I noticed there were times the disc had issues wiping out the tractors tire tracks in plowed ground. So, you either ran the disc a little deeper or just tolerated the job you were doing. Installing duals eliminated the problem and the tractor looked way cool.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 9:57am
Mine have eyes welded on the ends of the rails for clamp-on type,--I never use them, too much extra weight for my use.
I used to help a neighbor back in 1965 that ran the clamp-on type on his 45 and on a wd, they worked ok, so I would say that type was the norm.
Edited by ac fleet - 01 May 2019 at 9:57am
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2019 at 10:51am
i have heard of people running another set of spinouts and turning the center back to back and bolting through both.  but not something ive been around
This page was generated in 0.500 seconds.
