720 Serial number location
JoeO(C-MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(C-MO) Quote  Post ReplyReply Direct Link To This Post Topic: 720 Serial number location
    Posted: 29 Apr 2019 at 6:09pm
On earlier 720 I had the serial number was a tag on RH side frame in front of filter.
Has this changed?  I'm not seeing one on this one..
D10 III, D15 II 3 pt, D15 II SC, 170 Gas w/shuttle, 175 Diesel UI ROPS, 185 w ROPS. AC 653 w/6 way blade, ROPS
AC 615 Ind. WD45 running/Parts.
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2019 at 7:01pm
I do not think that it ever changed but if you are not careful with a good pressure washer...it will be gone before you know it. Don't ask how I know. Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(C-MO) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2019 at 9:05pm
No trace-no adhesive in the area.  Doesn't look that clean either, maybe long, long ago!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2019 at 8:54pm
That’s the correct location. Must have been removed one way or another.
