7020 pwr shift
mike-mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike-mn Quote  Post ReplyReply Direct Link To This Post Topic: 7020 pwr shift
    Posted: 29 Apr 2019 at 8:57am
Looked at a 7020 pwr shift yesterday.  It is pretty clean for its age, and runs great.  One problem it has is that it does not want to go into low on the range transmission.  Grinds like it doesn't travel enough to slide on the gear.  Is that something that could be a cable or is it internal, clutch brake needs adjusting?  I have only driven a 8030 pwr shift which shifted a lot harder between the gears than the 7020.  Is that a difference between series or is something else an issue.  Thanks again for any help.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2019 at 9:27am
Check clamp that holds front of cable they come lose and also bracket at rear of cable that bolts on top of stub shaft has one bolt bracket gets play then it don't shift in to low range
