All-Crop Bundle Topper
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: All-Crop Bundle Topper
    Posted: 27 Apr 2019 at 4:36pm
I've got a bundle topper I need to install on my 60A. Great-granddad used to use it some, so the holes are already drilled in the header sides to mount it there. My question is how do you attach it to the combine's sickle bar? I'm guessing you use small bolts through two sickle sections, after punching out the old rivets, but I just thought I'd see if anyone here has any experience with that.
Thanks!
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2019 at 10:30pm
I'm curious to what that looks like if pictures could be put up.
Thanks
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2019 at 10:35pm
yes we need pictures
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2019 at 10:46pm
I thought I sent ya some pictures of how that attaches..I'll look for them tomorrow and see if I can get them I'm here
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 4:12pm
Here ya'll go my 60 with the bundle topper attachment
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 4:23pm
Ok I give up. What's the purpose of this?
Life is tough,but it's tougher when you're stupid. - John Wayne
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 6:59pm
It’s a bundle topper.
It basically turns the combine into a stationary threshing machine. After using your grain binder, you take the bundles to the combine, and holding them horizontally, pass them down over the bundle topper sickle bar. Then the heads go up into the combine to get threshed, and you don’t have to run all the stalks through.
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 7:28pm
OK. Now a stupid question from me. Why wouldn't you just use the combine in the field as it was designed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 7:36pm
That part I don't really know. Great-grandpa used it on kaffir, which was pretty tall back then, before shorter "combine" varieties were bred. I'm thinking since the header wouldn't raise up near high enough (without the high lift attachment) to take just the heads, they bound it and used the bundle topper. Maybe this was their solution to keep from threshing the whole tall plant?
I'm just doing it to try out the bundle topper, and have some fun using it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 7:53pm
yes, for such things as kaffir, or higeri(sp), red top cane, and others that got really tall
these were prolly bundled when the stalks were still really green, but seed had matured, the 'butts' were ground in the hammer mill, or fed whole to the cattle..
 a really dangerous attachment,,, as you can prolly tell by looking..
I can remember this being used by my grandparents....
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 8:09pm
By using the topper they could use the straw. No big V rake and bailer to follow the combine.          MACK
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 8:54pm
Looks like item #9 attaches to the cutter bar.
Hope this helps!
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 9:56pm
Thanks. That’s interesting, I’m missing part 15 and 16, that spring. I guess I better look at my book and see what that’s for
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 10:45pm
I'll hafta look and see if those parts are on mine,, also have another one,not on a machine, not sure if its complete
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2019 at 4:36pm
Wow that looks dangerous
Edited by Bill_MN - 29 Apr 2019 at 4:36pm
