What tractor to use?
CDR,Ky. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDR,Ky. Quote  Post ReplyReply Direct Link To This Post Topic: What tractor to use?
    Posted: 01 Aug 2010 at 9:38pm
I'm thinking of doing garden rototilling and bushoging for a side job and was wondering what size tractor would be good?Maybe a D15 or a 160?Any advice would be appreciated.
If you first don't succeed then you'se brute force!
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2010 at 9:42pm
See what you can find and what your budget can afford.  They are both nice size tractors.  Do you want a 3pt hitch?  If so I would insist on a factory one, gas tractors are easier to fix but that is another option you need to decide what you want.  I have always heard the 160 is hard to get parts for.  Good luck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2010 at 9:59pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2010 at 10:06pm
I'd definitely go for a 15.  The power director would be very handy for use on a tiller.  I think an aftermarket 3ph would work just as well as factory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2010 at 10:12pm
I hate aftermarket 3pt hitches.  Years ago we had a D19 that had an Abott hitch, the tractor had been used on a roto-vator, it was worn out and would come u hooked from the snap-coupler when pulling hard.  Besides this the geometry was wrong on it, it was hard to get some tools to lift very high.  Another thing, I believe Allis Chalmers tractors had one of the best 3pt hitches on the market.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CDR,Ky. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2010 at 10:40pm
Sounds like I should stay with the D series.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2010 at 11:05pm
I used to run the D series, then went to the 170/175 diesels.  I do tilling and brushhogging for hire, and find it is hard to beat the torque and economy of the Perkins diesels! I gross close to $1000 on every tank of fuel I burn.
ALLIS EXPRESS!
This year:
clint View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote clint Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2010 at 8:29am
you want slow ground speed for a tiller- i would go 170/175
Our farms stuff: agco gt55, AA 8775, 8765, 6080, 185, 180, 175, 170, d15, d14, d14, wd, wd, wd, g, F3, L3, R62
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2010 at 8:49am
You might investigate what size gardens you would be doing and the access to them.  I have a Case 446 with a Cat 0, 4' hydraulic tiller that works great for a large garden I do.  I have plowed and disked it with my D14, but then, I do have room to run around !  In a residential area a large tractor may not work the majority of the time.
