WTB C plow brackets
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: WTB C plow brackets
    Posted: 23 Apr 2019 at 3:37pm
I am need the brackets that bolt to the final drive and drop down to hook the plow pull bar to.  I know this is a B  but i have the same setup but missing the the final bracket.  also how does that that angled bar work on the plow.  looks like a loop is on the lift bracket of the tractor but mine doesnt have anything there it must be broken.
PM is fine
wiplowboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wiplowboy Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2019 at 10:30pm
Have a bunch. Send email address for pictures
Mtcranch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mtcranch Quote  Post ReplyReply Direct Link To This Post Posted: 28 Nov 2020 at 9:06pm
If you still have any of the model c plow pull bar and brackets I am in need of one. Please email me if you do. Mtcranch7@gmail.com
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 29 Nov 2020 at 7:32am
The C tractor uses completely different brackets that the B tractor does.  For the depth adjustment a C uses an arm the bolts under the right foot rest and has a rod that goes back to the right cultivator adjusting lever
   The picture that you are showing of the B doesn't have the angled rod in the slide tube. This must be clean and allow the rod to slide freely. This is a maintenance  item that never seemed to get done over the years as many plows I see have all the rods and lift links mangled or broken.
