2005 Saturn Veu front brakes
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 2005 Saturn Veu front brakes
    Posted: 20 Apr 2019 at 1:29pm
Got a 2005 Saturn Vue and having front brake issues , heres what happened, passenger side front brake caliper stuck one day so replaced the rubber brake line , it had a shimmy when applying the brakes after , and they were wore down so replaced the front brake pads and rotors on both sides, also replaced the wheel bearing assemble as it had a little play too,caliper / brake come on ,relubed the sliding pins ran good for a few weeks and done it again , put a new caliper on it , now it drives great but sometimes out of the blue its like the passenger side brake comes on with a grinding noise then stops after a bit, no ABS light comes on , im stummped !
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 1:43pm
I had a car do that before and ended up replacing the proportioning valve. Your mileage may vary.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 4:28pm
Its got 197000 on it so probably a good thing to replace, or its in the ABS controller thanks
Edited by DougG - 21 Apr 2019 at 7:00am
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2019 at 7:22am
Does it sound like the ABS pump is coming on when you say a 'grinding noise'?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2019 at 8:23am
could be a slug of air in the other side brake line.
It took me 6 tries to get AIR the air outta the forklift brakes and that only has 3' of tubing ! A slight bend was allowing the bubble to go back and forth...
sigh.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2019 at 9:36am
No noise from the ABS
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 11:31am
You changed the hoses and calipers did you use a tech 2 and bleed the brakes if not your ABS module probably has air in it. It wont cause the ABS light to come on but you wont get a good bleed without comanding bleed mode in the ABS
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 2:20pm
Gotta love them A$$inine Brake Systems. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 4:37pm
Didn't do nothing like that Dave just bleed them the way I do with others, gotta do some homework!
Edited by DougG - 23 Apr 2019 at 8:05am
