Saw an interesting problem today
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Topic: Saw an interesting problem today
    Posted: 19 Apr 2019 at 10:23pm
I stopped by a friends house to look at a tractor she had told me was leaking oil.  It's an older Kubota, an L2850.  Anyway she pointed out the breather tube and said her husband thought it the leak was coming out of there, she thought it was diesel fuel.  I pulled the dip stick and fuel shot out of the hole for a while.  I told her I thought the seal between the injection pump and the engine probably is bad and the fuel is leaking from the fuel tank into the engine.  I suggested she have the Kubota dealer look at it as I havn't the slightest idea how the engine is built.
Allis Express participant
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2019 at 10:46pm
Not likely the injection pump. Check if it has a mechanical fuel lift pump. It should be a diaphragm pump mounted on the rh side of the engine near the injection pump. That is the most likely problem.
Rh
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 3:08am
    I stopped by a friends house to look at a tractor "SHE" had told me was leaking oil
   UMMMMMMMmmmm,,,,,,.,John,,,I kinda want to hear "the rest of the story",,,seein as how you is now a celelbrity in them parts,,,,,,,,WinkWink
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 6:11am
    <span style=": rgb254, 252, 212; color: rgb0, 0, 36;">I stopped by a friends house to look at a tractor "SHE" had told me was leaking oil</span>
</span>
<span style=": rgb254, 252, 212; color: rgb0, 0, 36;">   UMMMMMMMmmmm,,,,,,.,John,,,I kinda want to hear "the rest of the story",,,seein as how you is now a celelbrity in them parts,,,,,,,,WinkWink</span>
</span>
</span>
Now that’s funny. I was gonna ask almost the same. 😆😆😆
Recently my neighbor had me come look at his Kubota. He said he was told it had blown a head gasket. I checked the oil and it was milky. He said they changed it twice already. I noticed the radiator had silicon all over the top of it.
I pulled the radiator cap and it was full of fresh antifreeze. I told him to turn it over as I looked down in the radiator. I got a face full of antifreeze under pressure. It shot 30 feet in the air.
He and I both learned something.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 8:54am
Some days does not pay to be of assistance! Guy asked me to look at a hydraulic leak on his crawler, said he could never get a drip to show but losing fluid. Go to house, he fires it up(Cat) raises the ripper first and I see the oil shoot out across the lawn, then I saw the stripes, asked if he had been using it recently said a few times dressing the lane. Pointed out the stripes and then the ripper cylinder fitting split so he lets it down without thinking and I got a shower.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 1:45am
"SHE" is in her 40's I guess, known her since she was a teenager, making out with her boyfriend, now husband behind their Farmers Market Booth. Now has three daughters, one in collage the other two in HS.  She has always had a large chest, shall we say, and the day I stopped by it seemed to be unrestrained under her sweatshirt.
If I get the chance I'll look up the engine to see if it does have the fuel pump, thanks for the advice.  I still think I'll let the dealer, or someone else work on it, I've got enough projects.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 3:15am
 CHIT,,,John,,,stop!,,,stop!,,,,,my dang palms is mighty sore,,,,,on second thought,,,,don't stop tell us more,,,,!! I'm conjuring up some mighty delicious thinkin on your descriptions,,,,,,especially the part with the large chest and more especially them bein unrestrained whilst you two "visitin" way out in the country, behind the barn,,,,,,,,alone,,,,,,,chit there goes my other palm,,,,,,OK,,,when do we hear ,,,,,(pant, pant),,part II,,,,,,,,,ps,,,you a good story teller,John,,,,ClapClap
lentsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lentsch Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 9:14am
Need pics.
WD,D15,190XT,7000,8010x2,7060,8070
Wayne180d View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne180d Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 9:34am
You sure you are going to look up her fuel pump or look up something else and see what fuels it.  I thought you would look at the fuel pump  LMAO
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 10:00am
Wink Joe, LOLLOLLOL you keep Wink helping John tell a story where going to have O'l Shamefull howling like your big lovable puppy.
 Wink An ant nobody going to get anything fixed today to make Earth day fanatics go off to the "safe" closet and cry.LOL
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 10:03am
Maybe just a little knob adjusting and some lubrication will take care of it, but then again that could back fire in your face. Wink
Edited by chaskaduo - 22 Apr 2019 at 10:04am
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 2:42pm
I thought maybe you guys needed a little excitement, especially Joe, who really should have better things to do, like make sure Hungry isn't and his old lady, er, loving wife, is comfortable.
This is all I'm gonna say about restraine-ment.  You guys will just have to use your imagination!
Oh, one other thought, Dale, she lives less then a mile from one of your stockholders...
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 2:49am
well maybe I should talk to her in helping with the stockholder...you been failing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 9:14am
Carefull Shammers that could be collusion. Wink
Edited by chaskaduo - 23 Apr 2019 at 9:14am
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 11:59am
You are right Shameless Dude, I have failed you!  I'll have to try harder.
Don't want any collusion going on around here.  Then again I could haul the offending tractor over to the stockholders front yard so it can drip diesel on his lawn...
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 6:28am
 UMMmmm,,,,,UMMmmmmm,,,Shameless,,,,,I'm wonderin how ole John knows where thet stockholder lives,,,Chit they may even get together at them Farmers Markets to kinda share some gossips,,,,SAY,,!!  Shameless,,,you ever consider "how" them stockholders just happen to know "beforehand" what all you plannin,,,,,??? Mayhaps,,you gonna have to raise your antee to ole John,,Ya know just to make sure he stays ,,,,,,,,,,honest,,,,, him bein a celebrity and all,,,,,,,,,Wink
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 8:25am
It has a small round mechanical fuel pump below the injection pump and it can put fuel in motor. 2850 were a Great tractor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 8:59am
Toybuilder that's funny. LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2019 at 12:34pm
I  stopped and looked at it again, didn't go to the house to visit.  It looks to me that the fuel pump is attached to the injection pump, don't know how the fuel would get to the block.  I see the hydraulic pump is hooked to the injection pump and it doesn't have paint on it, making me think it was replaced.  Maybe something caused it when mounting the hy pump?
This page was generated in 0.489 seconds.
