Part needed for WD hyd. pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: Part needed for WD hyd. pump
    Posted: 01 Aug 2010 at 5:39pm
Was trying to free up the hyd. controls on the WD I have been slowly fixing up, and the control arm screw lock was rusted tight.  As I was trying to heat it and turn it loose, I twisted it off.  Does anyone have the control arm screw lock, which in my WD45 diesel part book is part number 223332, or a complete hold positioning valve off of a bad pump?   It would be nice to find a whole assembly as it looks like it's might be fun trying to get the rest of that screw out as it is broke flush on one side and the tapered end is still short of the other side, and it looks like I am going to have to pull the whole camshaft assembly(223355) out just to drill and try to easy out it.  I can take a picture of what I broke if that would help, that's why I put the part number on here.  Any help would be appreciated.
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2010 at 7:37pm
Chuck...I have the complete control valve assy, a core unit or a camshaft only.  And of course the lock screw.....Dale
Orangereborn
Dale Schafer
964  192nd Ave
New Richmond, WI 54017
715-247-3079
715-781-2055
Orangereborn@hotmail.com
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2010 at 7:44pm
  we can furnish any patrs you need   screw ,cam or valve   complete pump
   1-800-254-3116
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2010 at 8:54pm
Chuck...I did a PM but your box is full?   Dale
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2010 at 9:25pm
emptied it out some
