hd-5 |
jturano11
Joined: 26 Mar 2010 Location: Pennsylvania Points: 34 |
Topic: hd-5Posted: 01 Aug 2010 at 9:07am |
I developed a leak at my drive sprocket, it's comming from my final drive. can anyone help me with new seals? also looking for new seals and packing for all my cylinders on my hd-5 loader.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42274 |
Posted: 01 Aug 2010 at 8:00pm |
Loader seals are a V ring packing and can be found at hyd shops or I believe McMaster -Carr also carries some of that.
Inside or outside on rear sprocket as there are seals on both sides. To change those seals you need to drop the track frame from machine. No way to get the sprocket off unless you do .. If it is a 5G I have found another way but requires cutting and welding of truck frame.
