What transmission fluid for Allis 20-35?
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Topic: What transmission fluid for Allis 20-35?
    Posted: 31 Mar 2019 at 8:50pm
Hi all,
I previously asked around and found out that the general consensus for engine oil for the 20-35 is either straight 30 weight, or 15w40 diesel engine oil.
OK, now how about the transmission?
I don't believe I have asked this one yet, and I wasn't coming up with anything by searching.
What do you all run in your transmissions?
Trying to get all these details figured out for start up this summer, thanks!
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 9:24pm
Jacob. I use 140 trans oil in mine. Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2019 at 10:10pm
Thanks Dave, I keep meaning to call you to catch up.   It's been a while.  One of these days, I swear.
Anyone else have a 20-35 with fluid in the tranny? LOL
Jacob Swanson
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2019 at 9:29pm
I put 80-90 in my UC.The stuff that was in there musta been original.Resembled plastic roofing cement. Had to dig it out.
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 11:48am
It was a substance called extra heckela, Mobil still makes it, I took 80-90 and poured in a pail and used a mixer on a drill and put gun grease in it and mixed to make it thicker, works great. 4-11-19 update.  I found more info and Extra Hecela was 600 wt oil. I found records that I used 80/140 and added gun grease, 600 wt is quite thick, however it helps with remaining on the gears for lubrication.
Edited by Darrell G (MN) - 11 Apr 2019 at 11:14am
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 10 Apr 2019 at 1:05pm
Jacob, I looked for the barrel I used in my A but it is long gone I suppose. I'm 99 percent sure it was 140 wt also.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 11 Apr 2019 at 8:44am
I am going to use 140 wt gear oil and a couple gallons of that thick Lucas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 10:04pm
Thanks for the advice, all other advice is welcome.  I realize not nearly as many guys here are running these old ones as say WD's or whatever.
For reference to others that may be seeking this info, this document says the transmission holds seven gallons of oil.  Which sounds about right because I know we drained out over five gallons worth of sludge from mine and it was not full.
Link, see page 18:
Edited by Jacob (WI,ND) - 13 Apr 2019 at 10:10pm
Jacob Swanson
Leesok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leesok Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2019 at 10:25pm
000 pourable grease in all pre 40 trannys and rear ends around here.
This page was generated in 0.254 seconds.
