Overloading a 720?
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Topic: Overloading a 720?
    Posted: 31 Mar 2019 at 3:35pm
I really enjoy playing with the AC720 (in a large vegetable garden).  I have used a plow, tandem disc, and cultivator.   I sure do not intend to overload the hydro.  Are there indications that one should be aware of when one has the hydro loaded to near max? Herb(GA)
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 4:09pm
As I understand it...you have 2 lights on the dash. One is engine oil pressure warning and the other is the hydro warning light. Lets say you are in high range and the hydro light comes on...it is getting too hot so you should shift down a range (or 2). Now is this telling you if you are junking your hydro...yes and no. If you persist with the high range and light on...you are not doing your hydro any good. Wish I could tell you more. Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Todd Domann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Todd Domann Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2019 at 6:45am
Den, Do you know what the setting of the hydraulic oil temperature switch is.
Thanks, Todd
Todd Domann
JoeO(C-MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(C-MO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2019 at 8:31am
Manual shows 225 deg. F.
Edited by JoeO(C-MO) - 19 Apr 2019 at 8:34am
D10 III, D15 II 3 pt, D15 II SC, 170 Gas w/shuttle, 175 Diesel UI ROPS, 185 w ROPS. AC 653 w/6 way blade, ROPS
AC 615 Ind. WD45 running/Parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2019 at 11:26am
Operate the gear transmission in a slow enough gear that the hydro is nearly or fully maxxed out for whatever job you are doing. You wouldn't operate a combine in 3rd or 4th gear when in the field, would you ?? Same with a 616-620-720.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Todd Domann Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2019 at 8:13pm
Thanks Joe!
Todd Domann
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2019 at 9:00pm
As Dr Allis said select the proper gear. The tractor really should never strain pulling any of the factory attachments. 1st gear for tiller, brush hog, sickle mower, snow thrower, plow, belly mower, front or rear blade. I have each of those and have never over worked my 720. Have never seen the hydro temp light come on. Belly mower and sickle mower can be run in 2nd gear if the grass isn’t over grown. 3rd gear is a road gear only.
