WD pivot bolt
savedallis1953 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote savedallis1953 Quote  Post ReplyReply Direct Link To This Post Topic: WD pivot bolt
    Posted: 29 Mar 2019 at 6:10pm
Does anyone one here know where to purchase a pivot bolt for a wide front WD? Thanks again.
1953 WD, 1953 WD, WD engine with WD-45 crankshaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2019 at 9:55pm
What do you mean by the pivot bolt ??  The rear pivot has a castle nut on it, but the threaded portion is welded to the axle frame. The front pivot is also welded to the axle and it isn't a bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote savedallis1953 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 7:17am
The rear pivot bolt is what I am in search of.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 7:21am
The actual rear pivot point is a welded part of the axle framework. Either weld it up and grind it down to size or cut it out and replace it with a 3/4" bolt with the head removed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 7:24am
Might be a 7/8" bolt.....measure it.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 7:54am
I made up some new rear pivot supports for the wide front. I have one for sale if you are interested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote savedallis1953 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 7:55am
Thank you Doctor, 7/8"
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 7:57am
I don't think it's even avable but here's AGCO part number 70219900.
Post Options Post Options   Thanks (0) Thanks(0)   Quote savedallis1953 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 8:01am
Hi Lon I am interested in the item you mentioned.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 9:06am
I take mine to the local fab shop to get fixed up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote savedallis1953 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 2:39pm
Thanks to all of you for the information. Looks like I will be doing a little fabricating. Love this site.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 3:58pm
I fixed one of my WD's by cutting off the "bolt", then, welding a new 7/8" in its place. then on the support I found a 3 point bushing, I think it was a top2-3  bushing,, not sure,, just got the one that was 7/8" I.D. fitted and welded it in the support, ground to length,, only boo boo I done was I didn't get the cotter pin hole drilled in the right place in the new "bolt"... I jus lock nutted it... has worked good so far,, took biggest part of an afternoon to get it done,, for some reason the front pivot wasn't too bad...
Post Options Post Options   Thanks (0) Thanks(0)   Quote savedallis1953 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 7:01am
I welded and ground, ground and welded, filed, rested, filed some more and after only 3 or 4 hours......done. Front pivot "rod" looks good. Thank God.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2019 at 9:12am
Drill and tap a hole for a grease fitting while you're down there. This time it'll last 100 years instead of 50.
