D-19 clutch
MBolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MBolton Quote  Post ReplyReply Direct Link To This Post Topic: D-19 clutch
    Posted: 31 Jul 2010 at 8:51am
My "new" D-19 has a wobbly clutch peddle. Took it part last night and the peddle hole is egged shaped particularly on the inside. The shaft is worn too. Can someone tell me the
original dimensions of the peddle hole and shaft? What is the best fix when the hole is egg shaped?
Ken
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2010 at 8:54am
i would think one could dril out the hole and install a bushing .. otherwise a new pedal ? sorry i dont know the specs
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2010 at 8:59am
D17 & D19 clutch pedals should have two replaceable brass/bronze bushing.  I got a set from AGCO in 2006 for my D17 Series IV.  The are probably fairly expensive.  I don't have the dimensions off hand but it's probably a 1 inch shaft (ID) and 1 1/8 OD bushing.  Go to McMaster-Carr and I'm sure you can find generic ones easily for pretty cheap.  Look at your pedal closely and pull out what's left of the bushings and you can probably measure what's left.
Even if the shaft is worn, replacing the bushings will be a big help.  You have to split the tractor and get inside the PD housing to remove the shaft.  You'd then take it to a machine shop that does that kind of work to weld it up and turn it back down to dimensions.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2010 at 10:49am
I have a machine and fabrication shop fix all my clutch pedals.  Measure the shaft with calipers, then they can make and put a bushing in the pedal.  Makes a big difference!
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2010 at 1:34pm
We just got the old bushing out and put a piece of copper piping in there..
"Better By Design"
