WD wiring
Slowmotion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Topic: WD wiring
    Posted: 24 Mar 2019 at 1:19pm
I recently bought a WD that was about to be parted out. The fellow who owned it had bought it at an estate auction. I thought it looked too good to be parted out. It has no battery box or battery, and the generator looks as though it has not been wired into the electrical system for many years. My guess is that a battery was used to start it, and the battery was recharged between uses with house power and a battery charger. I know little about such things, and I’m wondering if that would make sense, and if putting a battery box and battery back in the system would be a reasonable approach to trying to get it running again.
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 4:40pm
Your theory may be correct. That was the was how our Super M was before we inherited it. Generator was bad. After FIL died we just charged it overnight to use all day for cleanup. Just didn't use starter. Now that it's ours I converted to one wire alternator
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 4:44pm
I would do something temporary to hold a battery and try to get it running before buying a lot of parts. Distributor or magneto? Any idea if it was last run as 6 or 12 volt? If a distributor and there is a ballast resistor in the wiring ahead of the coil, they were likely running a 12 volt battery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 5:28pm
If you have a magneto ignition, a good battery will start the tractor many times without recharging, IF it's tuned up properly. I know a guy that has been using a 12 volt battery for years that way. He might put the charger on it once a month, just so he knows it's good to go the next time he needs it.
 I would find out how good the engine runs, before putting time and money into a charging system.
Walter(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walter(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 5:29pm
Figure out a way to hold a battery temporarily. You can hook up a battery and find out if motor is free or use a crank to check motor.  If engine turns with  a battery try to start the tractor with fresh gas and check for spark.  No need to spend money on things like battery box and generator until you know what you are dealing with.  Simple things first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 7:28pm
It will turn with a crank. There is a heavy rubber strap near the battery platform that looks like it was probably used to hold a battery in place.
I would like to know if there are any major problems before I sink a lot of money into it. I need to figure out for certain if it’s 6 v or 12 before I buy a battery. I can’t lift car batteries anymore, so I’m going to put a battery box on it and get help putting a battery in it. If it’s worth a rebuilt generator, I wonder if it would be worth converting it to an alternator? If I get that far, it seems like this would be the time to do it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 7:48pm
The spark plug wires come out of a bare metal attachment that has Fairbanks Morse Type FM on its side. It’s bolted onto a large metal thing that’s the same color paint as the rest of the tractor and appears to be original equipment. It has the firing order on it. At the front end of this is another bare metal piece bolted on that appears to be part of whatever the back end piece is. I see no coil or ballast or anything else.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 8:01pm
You said the generator is unhooked, so you don't need to be concerned with it for now. If it has a magneto ignition system you can use either 6 or 12 volt battery to try starting it. If it has a distributor with a ballast resistor in the wire going to the coil it should be ok to use a 12 volt battery. If no resistor the battery needs to match the coil. With no battery hooked up take an ohm reading between the two primary wire terminals on the coil and post the reading. Battery voltage the coil is for can be determined from that. Polarity of the battery should also match coil polarity. Post a few photos someone may see something that might help. Good luck, hope things come together for you and it starts easily.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 8:02pm
You have a magneto ignition.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 8:16pm
So if I have a magneto ignition and there is no coil, do I use a 6 volt or a 12 volt battery to start it. I used to have an F-20 that I cranked with no problems, but I'm leery of cranking now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 8:30pm
It won't care if you use 6 volt or 12. Just don't crank it for long periods of time.
The Magneto has a coil, inside, but doesn't need outside voltage. The mag makes it's own spark.
 If there is a wire hooked to that little stud with the metal tab, remove it. It's a ground wire that shorts out the spark of the mag and if any part of the wiring or switch is grounded, it won't have any spark. You push that tab in to shut the engine down.
https://i.ebayimg.com/images/g/P6EAAOSw4vpcCdYM/s-l300.jpg
Edited by CTuckerNWIL - 26 Mar 2019 at 9:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 8:48pm
Looks like I pretty much have the info I need to move forward. Thanks everyone. I'm keeping my fingers crossed.
Krazy Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Krazy Karl Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 9:31pm
Previous ower probably cranked it over by hand. And didn't use battery. Believe in operator manual states if not using battery to unhook generator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2019 at 9:50am
With a magneto ignition, there is no need to buy a battery until you figure out if it's worth investing $ into. You can jump the starter with any 12 volt car or truck , just make sure you don't have any connections from the battery to any of the old wiring.
 Find out if it's gonna run, then worry about a charging system and battery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2019 at 2:41pm
Where would the starter switch mount on this tractor? The control panel box is hanging by a wire, but there's nothing in it. I see a started switch advertised that seems to be contained in a box that is the same size and shape as that box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2019 at 2:07am
After doing a lot of digging, the light finally went on and I found where the switch is supposed to be, and it's there. And the long rod that's used to engage it is also there and attached. It looks like all I'd have to do is attach a battery. But I'll drain the fuel tank first and I'm thinking about changing the oil. It doesn't appear from what I've read and can see on the tractor that there is a fuel filter, other than the settling bowl. But maybe I should wait on changing the oil until I find out if it will start. The odds are probably 100 to 1 that it will need a new starter and switch. I bought a new battery box, and I'm wondering if there are batteries with terminals in the right place for the box?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 9:30am
If you follow original directions, "Buy Clean fuel, Keep it clean" there is no need for a fuel filter. That's what the sediment bowl is there for. It separates water and sedimenet from the fuel as it is used, and should be cleaned regularly.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 10:11am
Re: proper sized battery - yes. Take measurements of your battery box. You want a battery with top-mounted terminals. Take your tape measure to your local battery store of choice and start measuring. Make sure that the box lid will clear the terminals with room to spare.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 10:46am
Then add a piece of 1/4 inch plywood or hardboard flooring over the battery, before you put the top on.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 11:27am
there was a lot of tractors of all flavors sold without a gen, or battery, or starter, w/magneto during the war
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 12:21am
The 26R group looks like it's about the right size, but the terminals are opposite each other, and the openings in my battery box are staggered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 5:45am
Offhand I can't think of a 12 volt having staggered (diagonally opposite) posts like the 6 volt group 1 batteries. You will need to change or rework the cables to fit the battery you get. As it appears you are converting to 12 volts you will be best to configure it as negative ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 12:09pm
There's not much to convert. The lights and generator aren't wired up, and it runs off a magneto. I don't know if the starter is any good, but I seriously doubt it, and if it is, I've read that it should work with a 12v battery. Maybe the simplest thing is to cut another opening in the box. 12v is more readily available and probably cheaper.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 12:17pm
Maybe a longer cable would work before cutting the box.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 12:17pm
Look at a grp 26, I think it's bass-ackwards of the 26-R.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 1:51pm
A new cable with few more inches of cable should be able to use the existing openings in the battery box, even if the terminals are both on one side of the battery, not staggered.
A 26 has + on the left if looking down on the battery while standing on the same side as the posts. As DrAllis said, a 26R is the opposite, the + is on the right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 2:36pm
It looks like the cell covers would get in the way of one of the cables with either the 26 or the 26R, especially if I put an insulator between the posts and the lid.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 6:41pm
Before you start it the first time get a clean drain pan and remove the oil pan drain bolt for just a second to make sure you don't have a gallon of water in the bottom of the pan. If just oil comes out you can put it back in and go from there.🙂
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2019 at 7:20pm
Sounds Like a good idea. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slowmotion Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2019 at 7:17pm
I got the battery wired in and tried the starter today. There was a little arc at about where the start lever connects to the solenoid, and then nothing. I put a charger on the battery and it didn't register, just hummed. I'm thinking a dead short in the solenoid or the starter, but I know little about this stuff.
This page was generated in 0.143 seconds.
