wd 45 no start
trace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trace Quote  Post ReplyReply Direct Link To This Post Topic: wd 45 no start
    Posted: 22 Mar 2019 at 7:47am
Finally got out and worked on my 1955 wd45. Put a new starter switch on (looks like old dimmer switch) and started right up. Got er off the yard and onto the driveway. Went to take the tire chains off (wishful thinking) and she wouldn't start again. When I took the old switch off the paper stuff on the sides was wrinkled but no burn marks or anything. Any ideas? Any other ways to start without that crappy switch? Put this switch on couple years ago with new starter. All suggestions appreciated. Going to take 2 yr old delco battery to dealer and have it load tested.
Edited by trace - 22 Mar 2019 at 7:49am
1955 WD-45 WIDE FRONT W/ TRIP
LOADER
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 9:39am
Need more information!
What do you mean by "wouldn't start again": won't turn over? Turns over but won't fire? Why did you replace the old starter switch? How's your starting circuit set up - do you have a solenoid switch between the battery and the starter motor?
Assuming that it won't turn over and that the switch just delivers power to a solenoid switch, you can try jumping around the solenoid - that is, from battery cable post to output post. If that doesn't work, the solenoid is bad.
Let us know........
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote trace Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 9:48am
Had another thread earlier this month about not starting. When I got a chance changed the starter switch and it fired right off, wierd. Next day takin the chains off wouldn't make a sound just like before. New starter two years ago, new battery, cables and starter switch also. Going at lunch to have battery load tested and from there guess a new key switch would be in order.
   Wasn't aware there was a solenoid, where would that be??
LOADER
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 9:52am
trace,
Lots of reasons that they wont start. Agree, need more info too.
Spark, gas, and compression they should run. Good news is that it ran just prior, so it cant be that serious. Probably just did not want the chains off and was just throwing a little hissy fit!:)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 9:57am
trace, you may NOT have a solenoid. I was just guessing based on how you described it. Diagnosing the problem depends on how your starting circuit is wired. Can you describe where this switch is located and what wires are connected to it?
WC, CA, D14, WD45
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 10:08am
put battery cable right on stud top starter if it turns over it is the switch or stud is bad clean it good if too short replace it
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 10:37am
Could be just in the connection of the fittings on end of battery cables. Had that happen... even had a cable corrode inside the lead clamp and not make connection.
  Alternator was not charging for awhile, so I thought it was the alternator itself but put a jumper wire on it and it charged real good... so thought I had a bad wire connection... Yea, I did, inside the regulator itself on the switch side, never had one of those coils go toast... and no fixing that, so new regulator is on it's way. Keep checking till you find your problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 11:05am
Cold and wet weather play havoc with electrical connections & components. Its enough to make you pull your hair out sometimes. Not sure if you're still on 6V's or you switched it over to 12V, but a more reliable way to move away from that pesky switch is to install a Starter Solenoid and key crank start Ignition switch. The Starter will need to be flipped from the kick switch pad to a stud where the Starter Solenoid can connect to the Starter via the solenoid. A wire off the "start" terminal post to the #10 post on the solenoid activates the solenoid once 12V's energize that crank circuit and the other side of the solenoid is fed with the Battery. Viola! Just like your car or truck! Having the Battery draw tested is a good practice to do whether 6V or 12V! Glad to see family members here are learning!
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 11:36am
The starter itself could have a dead spot too. Again, not enough info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 3:30pm
How about some pictures from the battery to the switch to the starter?  That would help a LOT!  Especially the starter and wiring.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 3:33pm
Don’t overlook the ground path...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 4:29pm
Define "new" starter. Are we talking just a set of brushes and bushings? A weak or broken brush spring could be what's going on here.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 4:40pm
The contact bar under the button get a little dirty or worn and they wont work, Got a B starter that did that. Starter button looked like new but was worn /burned to the point of no contact.
Moneypit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Moneypit Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 7:26pm
Hand crank
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 7:52pm
The question needs MUCH BETTER clarification.   IF it's a stock WD/45, it has no solenoid- it uses a pull rod that directly acts on the starter switch button on starter.
by "won't start"?  Do you mean 'Won't turn over'?
You pull the starter rod, which pulls the start contact lever, which pushes the start contact button, and... does anything happen?
If not, check battery cables (both pos and negative), and then remove the starter button...
The contacts of the starter button may not be making good contact.
If you're pulling the rod, and the starter spins, but doesn't turn the engine over, different situation.
If the starter spins, engine turns, but won't fire, different situation yet.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 7:25am
Just a suggestion...
Take the starter switch off again and polish the inside contact points.  My CA wouldn't start once and I was sure the battery was good.  A little polishing/scraping and my electrical contacts were good again.  HTH.
Post Options Post Options   Thanks (0) Thanks(0)   Quote trace Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 9:28am
thanks everyone. getting a new battery today, old one tested ok but to my amazement was five years old. starter was a new rebuilt when i got it. going to try direct test on starter with cable today before it rains.
pull starter rod nothing happens, dead. will shine up contacts, check battery connections (is 12v with alt) and go from there. think will order new switch if nothing else helps. wealth of knowledge on here thanks for all the help. just a so so mech myself.
Edited by trace - 23 Mar 2019 at 9:32am
LOADER
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2019 at 9:52am
Don't care for know it all's myself. Approve
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 11:25am
Okay, Trace-  if your switch looks like the one Brian F showed a picture of, take it apart again, and cycle the plunger, and compare it to the post on the starter.  that contact is suppsed to bridge 'tween the battery and starter terminal.
I dealt with this a dozen ago on my B, and then again mebbie five ago with my WD45... the arrangement is same.  The B gave me royal fits 'till I figured out that the replacement switch (brand new, but aftermarket) was simply NOT moving far enough to bridging the contacts.  I'm pretty certain the starter post was a bit worn, but I'm also dead certain that the replacement switch assembly was misshaped crap.
Now, I've slept two or three times since then, so I can't tell 'ya what I wound up doing to make the darned thing work, but I pulled the switch apart and made some modifications.  I don't recall wether I wound up putting it in the mill, or hand filing, or rotating the starter terminal, or mebbie I put a spacer under the starter terminal to get it up higher... mebbie I added metal to the lever's nose, I simply don't recall... but that's what it needed.  And yep... it's a real PITA 'till 'ya get it fixed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote trace Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2019 at 5:48pm
Ok, got the new battery in. Touched hot line to starter post, nothing. Starter shot???
LOADER
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2019 at 6:08pm
Trace, I had the same thing happen to me and I was pulling my hair out, I change the starter, the starter switch, put new cable on, new battery, still no luck until I ran a ground wire from the frame to the instrument panel now she starts like a charm, you may want to try it before spending a lot more money it may not help but is a cheep fix to try. HTH you
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2019 at 6:52pm
Did you have the switch off when you hit starter post?----And also there are two different switch styles, one works only on Prestolite starters ! they look the same but the body has a different shape and won't work on delco units. I found that out on a B starter which I still can't get to work! Thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote trace Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2019 at 7:14pm
Kenny L, battery sparks when I touch frame so must have good ground.
ac fleet, starter has always worked fine with key switch I have. Switch was on when I hit starter post.
LOADER
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2019 at 7:34pm
Trace, mine did also
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2019 at 8:41pm
The battery might be attached to the frame but how is the connection between the frame to the starter itself? There is a pointed bolt that holds the starter in position and also is responsible for making the ground connection to the starter I believe.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2019 at 10:23pm
I don't think the key switch would have any effect if you are running a battery cable directly from the battery to the starter post. Wonder if the starter is jammed on the ring gear. I'd pull the starter out to rule this out. While it's out, test it directly with a known fresh battery and jumper cables.
WC, CA, D14, WD45
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2019 at 3:59am
Yes. What Dave said!
Post Options Post Options   Thanks (0) Thanks(0)   Quote trace Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2019 at 8:47am
Thanks guys!, rebuilt starter five years old. Will take off and test with my pickup battery. What weird about this is that tractor started two different times then wouldn't after I moved it. Thanks for all the help.
LOADER
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 9:04am
Is started jammed into the flywheel? That happens once in a while. Loosen up jam nut and jiggle it. (that's what SHE said)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2019 at 9:51pm
That right there suggests to me that you DO NOT have a GOOD ground.
Take a pair of jumper cables (auto type) and put the neg (-) RIGHT ONTO the starter somewhere where you have GOOD contact.  Now put the cables onto the battery and wiggle em so you've got good contact.  Now just touch that positive (+) cable to the starter switch post.
This bypasses the pointed bolt that holds the starter in in case that is NOT giving a GOOD GROUND.
That was the easiest way to find out if you have a good starter. (the starter COULD still be good, even if it doesn't turn over).....read on...
Take the starter OUT of the tractor, put it into a vise moderately tight.  This is so the next test doesn't twist it out of your hand and cut off the bottom of your pants.  That doesn't matter, cause you probably just got some chit in em anyway....
In the vise, put the negative (-) cable onto the starter OR onto the vise somewhere.  Now hook up to the battery and then touch the bolt on the switch and see if it spins.
The system is SO simple to work on.  Wish I was there with you, we'd have it going in a heartbeat.
