AC Forklift Hydraulics
Famous View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Famous Quote  Post ReplyReply Direct Link To This Post Topic: AC Forklift Hydraulics
    Posted: 21 Mar 2019 at 1:36am
I have an old AC forklift that has a problem with the tilt cylinders every time that I put a load on it and tilt it back it goes back down. I checked the cylinders and they don't seem to be leaking and they are non serviceable they are welded and don't have a screw out end. I also did change a line that was leaking on one side and the other side has a small leak I think. I also did change the fluid and does anyone know the capacity on these it has no dipstick I measured out 3.5 gallons and put the same amount in. I put ATF in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 6:16am
If you mean when it tilts back,release leaver, it then tilts forward, I think the control valve has a small blockage or bad O-ring or ?? Something that isn't allowing the valve to fully close,so oil leaks internally. You don't say which model lift, but my FPD50  tank cap has a 'dip stick' attached to it. I'd say fillup yours to say 2" below where the stem and top of  tank meet.
you can try www.liberatedmanuals.com for a manual, 100s of them there.
Jay
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 5:32pm
It's probably the cylinders leading at the piston seals. It seems to be the most common cause, at least all the forklifts and loaders I've had.
Leaking o rings on the valve cannot cause the problem. They only control external leakage. There are no internal seals in the valve.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 6:14pm
You say you checked the cylinders and they don't seem to be leaking. How did you check them? Visually, as you didn't see a leak out of the cylinder at the rod? The piston packings could be leaking internally which you can't see.
I don't know about those tilt cylinders but it doesn't seem that tilt cylinders would be non-serviceable (100% welded). Are you sure the gland on the rod end doesn't unscrew from inside the tube? If there is a bead of weld on that end I would wonder if someone had a problem and did that as a one time fix, for their use.
How much slop in the valve? If the centering spring was bad the valve spool might not be in center, closed to both sides of the cylinders, when you let go of the handle.
The model info and some photos might help.
