WD power steering
andrewMT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrewMT Quote  Post ReplyReply Direct Link To This Post Topic: WD power steering
    Posted: 19 Mar 2019 at 3:01pm
I'm thinking about finally putting power steering on the WD. I don't think my shoulders can take the "Armstrong" steering much longer.
I'm wondering about the pulley on the Eaton PS pump. It looks like from the pictures I've seen that the larger pulley (6"+/-) might be needed to get enough belt clearance around the waterpump, not the typical 4 1/2" pulley you see on most pumps. Or will the 4-1/2" pulley work?
Also, I'm seeing the slip-joint type couplers on the steering shaft where the torque generator is spliced in. Do I need the jointed couplers or will the solid ones work - they sure are a lot cheaper!
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 7:48pm
A new crankshaft double pulley for power steering is available in aftermarket.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 8:49pm
You will need the double crank. pulley to start with. I have a wd with add-on char-lynn and a wd-45 with what looks like factory ps. --weird lookin' setup. If you need pics. for ideas just ask!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 10:18pm
You will need the flex joints on each end.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrewMT Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 9:48am
So Mack, you're saying these will not work?
http://www.steinertractor.com/ABC497-Economy-Char-Lynn-Steering-Coupler-For-Tractors-With-U-Joint-
Edited by andrewMT - 20 Mar 2019 at 9:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 10:02am
 What would you be using that coupling for? If you add a belt driven PS pump, all you need is the double pulley on the crankshaft, no coupling of any kind. Mount the pump off to the side and run a belt from the second , unused pulley, to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 10:11am
Here's what you need. At the end, you can see the pump is mounted about straight above the center of the engine, with a belt diving it off the crank pulley.
https://youtu.be/SDhZbrfia7w
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 10:31am
I have a setup like this on a parts WD that I would sell. I am near Spokane.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 10:49am
You will need a coupler like that on each end of the char-lynn unit to connect the steering shaft back together! You will have to cut the precise amount from your existing shaft, then drill the pin holes to connect them back together, you also need a support in there .
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrewMT Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 11:12am
CTucker, I see on you're installation you've got the fancy 2 piece couplers with the slip joints on either side of the torque generator. That seems to be what everybody uses. Must be a reason so I guess I'll just have to shell out the $200 plus for a couple of those. They're pretty much the same price everywhere I find them.http://www.steinertractor.com/ABC380-Slip-Fit-Coupler-for-tractors-that-need-a-u-joint-
 I thought since it's a straight shaft maybe I could get away with the simple one piece ones with two roll pins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrewMT Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 11:21am
Thanks Eldon I sent you a PM.
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrewMT Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 11:56am
CTucker, or anyone else with access to one, you could answer my original question if you could measure the diameter of the power steering pump pulley - above the water pump. If my understanding is correct it should be either around 4-3/8 or 5-7/8.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 12:14pm
who sells the aftermarket crank pulley ? we just as well get all the parts required for his job identified.    because  thats on the list for my wd
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrewMT Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 6:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 7:49pm
That's not my tractor. I just snagged it from a google search. I have Factory PS on my 45.
 Guess I was having a brain fart , thinkin you were hookin the pump up with a coupler Wacko
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 9:30pm
If you don't lined up perfect, it will put side load on unit, causing it to leak and possible lock up. Best to spend the money now.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrewMT Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 10:40am
Mack I think I think you're onto it. I came to the same conclusion after thinking about it for a while. With the straight solid couplers there would be no give either alignment-wise or lengthwise, so even the slightest twisting or flexing of the tractor frame would put stress on the torque generator - it would be trashed in no time I expect. Guess I'll have to get the slip joints.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 3:49pm
Mine has a slip coupler on the end that goes to the steering wheel and a solid coupler on the other end. there is some play when you grab the steering wheel climbing of and on the tractor. the other end goes straight to the shaft support then down to the u joint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrewMT Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 4:23pm
Dave, now that makes sense to me. Should give the assembly enough wiggle room to work and saves you about $80.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 5:03pm
Char-lynn pump pulley's are 4-1/2" dia, on both of my wd's. pump sits directly above engine.  the wd-45 factory unit is mounted upper left of engine----totally diff. animal.
thanks; ac fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrewMT Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 12:31pm
Thanks AC Fleet - that's the most common size I'm seeing on the old Eaton (mostly Ford) pumps for sale online.
