7.3 issue
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: 7.3 issue
    Posted: 18 Mar 2019 at 8:18pm
The engine has started to gallop or surge at startup. The RPM's jump so much that the whole truck rocks side to side quite violently. It lasts for about 1 min or so then smooths out. It will repeat this start after start.
Would you any ideas?
Edited by DennisA (IL) - 18 Mar 2019 at 11:50pm
Thanks & God Bless
Dennis
baverwolf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote baverwolf Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2019 at 9:38pm
I'd bet that your getting air in the fuel system somewhere. Is this a powerstroke or older IDI? If I remember correctly we had a powerstroke that the drain on the fuel filter that sits on top of the engine started leaking. It would drain the filter when sitting for some time. It would start but run rough like you describe until the air was purged. Also I wonder if a bad glowplug or two would cause a couple cylinders to run rough until warmed up. The powerstrokes have the wires for the glow plugs under the valve covers and they do occasionally go bad.
Just my 2 cents..
Ben
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2019 at 10:35pm
Typical 7.3 --- Mine won't even start-----been 2 days wasted on it, still nuttin! damn junk diesels!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2019 at 11:40pm
Mine has been a good starter, even at a -4 with out being plugged in would start by just hitting the glow plugs a few times.
Not sure what the issue is now.
What year is your truck?
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2019 at 11:48pm
Just my 2 cents..
Ben
Thanks for the reply.
It's a 1999 Powerstroke. I'll take a look tomorrow and let you know what I find.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2019 at 9:05pm
Mine is a 97 F-350 ---has 118,000 miles on it, Had 99,780 on it when I bought it. Right off the bat, had to have new high pressure oil pump,pump gears, new turbo, new glow plugs, plus a whole bunch of other stuff. When temps. got below +55 degrees, forget about starting it. Sat all winter,  turns over, NO start. Messed some more today, still nuttin'
I can't get up on the engine, ole body won't hack it, and cant reach anything from the ground. can't climb on anything either.
Don't know if the injectors are now bad or the injection pump itself, engine always had a sharp knock  in it and according to a book, they say that indicates bad injector.
I am not gonna tear into it! ---hate diesel motors!
Problem is that's the only thing that I can haul my loader with. Explorer won't handle the tri axle trailer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2019 at 8:24am
AC Fleet, sounds like the previous owner didn’t take care of engine very well. Glow plugs can go anytime but injectors should last 300k.
I have 440k on the engine and the only engine work has been 1 set of glow plugs, under valve cover injector wires, turbo and turbo pedestal w/O rings. I believe that good maintenance and quality oils is key. I also use Archoil ar6200 and ar9100 additives.
Yesterday I started the truck and it had on issues. It started right up idled perfectly and ran down the road great. This is what’s so frustrating. I’m glad it’s running well, but I also know it will mess up again without warning. I what it fixed and move on, but do you fix something that’s not broke?
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 8:22pm
Check the connector on the IPR. That's the round thing down low in the valley on the HP oil pump. It's on the driver's side of the fuel filter housing. Also check to see that the stamped sheetmetal nut is on the IPR and snug. They are known to come off and the electromagnet can slide away from the base of the valve. The IPR connector seal melts over time allowing moisture in the connection and the pins can vibrate and loosen causing a bad connection. Also check the ICP sensor. If it has oil in the connector it's junk, replace it.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 10:08pm
The one i had, the wiring under the valve covers went bad. Not available from ferd at the time. Tranny went out at 116000 miles. Dang 7.3 went bad at 117000. Hope you find the problem hope its a cheap fix for you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2019 at 10:28pm
What went wrong with the engine? That should have gone 500k plus.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 8:09am
I am with Dennis here. My 99 has 340,000 miles, one set of glow plugs so far and two sets of valve cover gasket/under cover harnesses. The drain on the fuel filter replaced some five years ago as it failed. had the glow plug Relay Package fail one time so far, light cycled but no power to the plugs. Original injectors, basically all OEM save what was noted. Starts with a double cycle of glow plugs even in extreme cold, do have block heater plugged in when think will need it to ease up on the starter wear.
I would be looking to the filter drain, verify power to the GPs first, then pull the covers, check ALL the glow Plugs for resistance values and replace the cover gasket harness assemblies with any bad plugs.
Edited by DMiller - 22 Mar 2019 at 8:10am
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 8:32am
You probably already tried this? If not, try replacing it’s cam sensor. Here’s a Video link about it. https://m.youtube.com/watch?v=SgKkG0dcY7s
Edited by AC7060IL - 22 Mar 2019 at 8:33am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 9:03am
I forgot that on mine, is currently on its fifth one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2019 at 9:24am
I keep a cam sensor in the glove box but I’ve never had to use it yet.
Thanks & God Bless
Dennis
ebowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ebowman Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2019 at 12:15pm
Heater in fuel bowl?? Mine went bad few years ago. Took Ford 2 days to find
WD45, '62 D17 Diesel, '65 190XTD, '74 7030, 1958 Roto-Baler
This page was generated in 0.234 seconds.
