Newby Intro
Oldfrogdiving View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldfrogdiving Quote  Post ReplyReply Direct Link To This Post Topic: Newby Intro
    Posted: 14 Mar 2019 at 5:57pm
Hello Frog here, I just picked up a 65 AC B10, looking forward to tinkering on it, its in good shape considering its been sitting for over 20 years well relatively speaking, no compression in engine(im thinking of repowering) good snow blade, decent body, good deck. My plan is to get her moving and then consider my options, I like old tractors and have had several over the years.
Im not a mechanic but have been wrenching on mechanical things since a kid.
Currently looking for a flexplate/tranny shaft coupler for the old girl.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2019 at 6:28pm
Welcome, if you go to sponsors page and give sandy lake a call there great to work with
Animal Cracker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Animal Cracker Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2019 at 4:46am
Welcome there Frog, I have about a dozen tractors and I am not sure that I would re-power it. There plenty of parts still available and may help getting over the learning curve. Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldfrogdiving Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2019 at 6:32am
Thanks, yes I have been doing my due diligence, I do see lots of parts except that elusive transmission coupler flex plate dealeo. That AC is patiently waiting under my shed to be looked at. I'm about to pull the trigger on an early 80s Work horse, that only needs a carb rebuilding. My goal is to get an early garden tractor running and mowing so I can dump this PIA craftsman I picked up. thanks for the reply and ill be spending more time if I can on this site....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2019 at 9:03am
Are you talking about the little fiber disk that's bolting to each end of drive shaft, motor end and bevel gear box end. If so like I said above give sandy lake a call and they will help you.
