D 15 sediment bowl
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: D 15 sediment bowl
    Posted: 14 Mar 2019 at 1:19pm
Just cleaned mine as it had some rust particles in it . First time I turned it back on gas rushed in and it leaked . Second time the gas just dribbled in and no leak . So I'm thinking if the gas rushes in it ain't sealed . Even an old dog can learn something huh ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2019 at 5:34pm
Yep, you got it, the air leaks out first, then the gas...  I've gotten to be a pro at replacin the bowl and gasket, through the years, even gotta set of double punches, that cuts the whole gasket, in 3 strokes of a hammer...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2019 at 6:34pm
A new gasket always helps, the old one may be hard or have a nick and it is just about impossible to get it to seal. I have also seen the bowl have a little chip broken out of the top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2019 at 7:03am
A rubber? gasket seems to work best for me . Thanks for the replies .
