Oil filter
barky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barky Quote  Post ReplyReply Direct Link To This Post Topic: Oil filter
    Posted: 30 Jul 2010 at 10:22am
Can someone tell me the correct number for a Fram oil filter for a Wd 45
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2010 at 11:01am
C159
Post Options Post Options   Thanks (0) Thanks(0)   Quote barky Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2010 at 12:19pm
Thanks
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2010 at 7:50pm
If I remember right I keep reading posts that Fram filters aint all that. Can anyone respond, maybe Im wrong. Ryan
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2010 at 7:58pm
frams are not good filters even though they have caused few problems, the quality just isn't there. you would be better served getting a Wix 57011 or do like I do and just get an AGCO #70240912V filter from the dealer. be careful to look at the bottom of the filter as the new style bypass filters from NAPA and the like result in lower oil pressure. (see Tony's picture below). I will say no more as the oil filter debates tend to get a little heated LOL
Edited by Bill_MN - 02 Aug 2010 at 8:03pm
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2010 at 8:44am
Fram filters are junk.  Cut some apart and compare to a champion made or wix made filter and see the difference.  There is a reason no OEM will let them make filters for them.
Bill The 7011 napa filter is changed and the rubber disk/left filter is no longer produced and if I remember correctly carried a part number of 1011.  The last time I bought a napa filter however it was 19 dollars, just 3 weeks ago.  Tony has them listed at 10 dollars.  I need to place an order for a dozen or so.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2010 at 8:47am
After the NAPA/WIX fiasco, most of my customers wouldn't take a free NAPA/WIX filter.  We have sold the Hastings for 10 years and have been very happy with them
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2010 at 9:22am
If the Fram C159 is still stuffed with cloth, its drastically different from their crap full flow pleated paper filters. The AC engines with bypass filters depend on a lot of flow resistance in the bypass filter to hold up oil pressure, and a pleated paper filter won't do that. Only the cloth stuffed filter has proven to do that.
Gerald J.
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2010 at 11:36am
new Fram
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2010 at 11:56am
Big fish, please tell me you added all of the chaff for S$#t's and giggles?  Wow if you didn't.  Did they even run the cotton through the gin?  (I don't know much about cotton processing) or just take picked cotton right out of the field?
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2010 at 11:58am
Nope, that's the way they are inside.  Hulls and all!
JimD
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2010 at 1:35pm
http://www.fram.com/pdf/Fram_HP_Product_Specs.pdf   this is the filter i use with the d17 or egleanor oil filter housing. the ph8a filter is recomended for the d17 and 175 226 gas engines as you can see in the link the hp1 will interchange.
Edited by mlpankey - 03 Aug 2010 at 1:43pm
Dave Everett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Everett Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2010 at 1:59pm
Use a Baldwin T300M, best you can get, not the cheapest either.......or a fleetguard LF571 as a secong choice.........
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2010 at 2:18pm
I always use Purolator!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2010 at 5:20pm
Some D17 use the low pressure bypass filter and some use the full flow PH8. They are not interchangeable.
Gerald J.
kendak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kendak Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2010 at 5:51pm
the AC brand [bought from Sandy lake] Balwin & Purolator are also full of rice husk & whats called cotton mote...or trash as we call it here in cotton country ...my Dad owned a rice mill in the 60's & I can tell you rice husk will NOT absorb anything...they are there just to take up space ...kinda got to me when I cut open the Agco filter [after I blew my puller engine] & found husk in it....these are built like fuel-oil filters not engine oil filters
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2010 at 7:31am
  Most of the people on here will not pick up on the fuel/oil filter . It will go right over the head of most that all fuel/oil filters no matter what manufacturers name is on them will have a cheap cloth type media.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2010 at 8:06am
[QUOTE=Gerald J.]Some D17 use the low pressure bypass filter and some use the full flow PH8. They are not interchangeable. quote gerald j
you change the filter housing or live with the cotton fibers in all fuel/oil filters no matter whos name is on them
Edited by mlpankey - 04 Aug 2010 at 8:07am
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2010 at 9:50am
Gerald is not saying they wont bolt up, he is saying  they are not interchangable in application and he is correct. A full flow has to handle the system GPM and there is no way you can do that in X size canister and keep the microns the same. The by-pass filter element will filter out finer particals but wont handle the full flow GPM unless huge. This is why large diesels have both, the full flow to catch big stuff and make sure that all the oil reaching the bearings has some sort of filtration and the by-pass to filter out the fines.  If you want to filter part of your oil with a coarser filter that is up to you. Personaly I could care less whats inside of my Fleetgard LF571s as long as they are filtering as designed but things go over my head ya know?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2010 at 10:04am
wasnt anything personal butch .Alot of bad mouthing fram filters has been taking place on here . Most of which is comparing a apple to a orange. Not the same style filter. What I was telling gerald is two bolts hold the housing to the side of the block with a little effrt the entire housing can be changed to the full flow paper element oil filter . But then no one would have anything to bicker about now would they.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2010 at 10:19am
Dont worry about me I have developed thick skin on here. You are correct in that there is a lot of happy horse poop about about oil, filters and filtering. I generaly just stand back and enjoy the reading when the subject comes up but I fell in the swill this time, my mistake.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2010 at 10:26am
Ah...my morning entertainment...LOL!  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Aug 2010 at 11:12am
I was looking an early WC once, owned by a gentleman who had inherited the tractor from his Dad thirty-some years earlier, and mentioned that it had one of the very old glass AC filters on it. The owner replied that they were'nt sure what to replace it with, so they never did. That may be the solution, just leave it alone.
mdtractormechanic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 12:56am
Has anyone tried the Baldwin T-300M FILTER?
Joe's 1939 Model WC, 1940 Model RC, 1944 & 1950 Model C's, B-125 PU
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 4:15am
i use purolater too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 10:08am
OH NO!!! The Anti-Fram guys are at it again!! I've said it before, and I'll say it again, I've been selling Fram filters for 35 years, and NEVER had any of my customers lose an engine or had engine problems because of the oil filter. Not even on my own engines in my 1/4 mile door slammers or Dragsters that I used race for years. Speaking of Dragster's, tell the Top Fuel and Funny car guys that Fram filters are sh$t. If they were that bad, they wouldn't be screwed on a million dollar 8000 HP engine. I'll go along with Butch n' Mike. It is morning entertainment! I think my personal vehicles and my little Tractors will survive those bad ole' filters..  LOL!
Steve@B&B
chevytaHOE5674 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chevytaHOE5674 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 10:26am
They also tear those motors down after every few runs. They don't need the motors to last for days/weeks/years/decades....
Just something to ponder.....
Edited by chevytaHOE5674 - 11 Jun 2011 at 10:27am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 12:57pm
I don't know how you think you can use a pleated paper filter on a by-pass system like the older Ac's had. I'm sure you can change the filter bracket, but it has been proven that pleated filters WILL NOT cause enough resistance in the system to develop adequate oil pressure. Unless you plan on revamping the oil system internally a pleated paper filter will ruin you engine in a by-pass situation.
 As far as the fram filters go, they will work as good as any in a bypass system.
 Maybe somebody should build an add-a-bracket that would allow use of a by-pass filter and then what gets through that would go through a pleated paper filter. Then maybe your engine will last 100 years instead of 50.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdtractormechanic Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 1:11pm
I'm not anti-fram and I use Fram for certain applications. Bottom line is this, there is no one company that makes the best filter for every situation. As a heavy equipment mechanic for over 30 years I have seen many different brands of filters and have had to open them to diagnose failures. This has given me a birds eye view of the internal make up of these filters. In my field filters are pushed to the limits due to environmental conditions. I don't see Fram used anywhere near as often as I see Wix and Hastings.
That being said, in this particular application, the filter which provides the best oil pressure with in the guide lines of the machine's specs and still proves adequate filtration over the long term should be the filter of choose regardless of the brand.
As for the Baldwin filter, I have only used them in hydraulic systems. That is why I posted my question concerning the T300-M.
One more thing, I don't find it entertaining when someone is concerned about the breakdown of an expensive piece of equipment due to filter failure. Then again, I'm concerned about the longevity of the machine and not the sale of parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2011 at 2:37pm
mdtractormechanic,
I agree 100% with ya. I to am a heavy equipment and heavy truck mechanic that has  over 30 years myself. That's my regular job not a parts salesman selling filters. I'm responsible for taking care of a fleet for the local power co. and know what your saying. I also do a lot of Hydraulic work because our bucket trucks are equipped with 42-55' man-lift booms, & pressure digger derricks to set poles. You are absolutely correct. There are certain types of filters for certain types of jobs. Hydraulics is a whole other world, and so are the filters designed for those applications. To me, the entertainment end of it is how this subject (Fram) on the Tractors gets beat to death when a question arises, not so much the longevity of a product. Wix had a problem a while back with their equivilent to the C159 Fram. Yet, folks are right on it that Fram's version is junk. I sell a lot of C159's to our Tractor customer's and not one that I know of lost an engine because of the filter. They're all on my Tractors also. To me, its why condemn something when it hasn't had any issues. It works the way it was designed so far. Glad to see Wix jumped on that problem and revised the filter, especially for folks who only have Napa stores near them where they can purchase their service parts. As you probably know, Wix is one of the "giants" of the filter industry, also making the filters for Cat, and other mfr's per their specs. I am just as concerned as you about the longevity of a machine or engine at work. Some of our bucket trucks have close to a 1/2 million miles on em'. Not counting the endless hours these engines run while the linemen are in the air fixing the power lines day and night. Now we're talking longevity.....
Steve@B&B
This page was generated in 0.103 seconds.
